Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 19-02-2010, 20:34
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
Limit Switch Programming Help (Have almost all of it figured out)
We have set up our robot exactly how you did this, wiring wise and then we had setup our limit switch exactly how the frcmastery.com video said to do it.
How we have our robot setup.
- a kicker is pulled back(by a victor) until limit switch is pushed
- victor then reverses until a limit switch 2 is pushed
- then waits for a button to be pushed (and the kicker is released.(this is irrelevant))
We can't get step 1 to even happen.
From everything we have looked up it looks good multiple tutorials past examples above examples.
The only thing different that we just found out is that we don't have a DIO Module set up in the programming.
At the moment programming is unable to edit the robots code?
Unread 20-02-2010, 00:49
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Re: Limit Switch Programming Help (Have almost all of it figured out)
The last time I played around with one of the limit switches in our room, I found out that the switch will continuously output 1 if its NOT pressed. As soon as it is pressed, it will output 0. (I use C/C++)
So what I did was,
DigitalInput switch; // A variable that will get a value of 1 or 0 depending on the limit switch...
then
swich(13), // The port id it uses
then in the Tele op continuous,
if button 2 is pressed then
turn the motor in the + direction
and
check if switch is equal to 0
if switch is 0 then
stop the motor
or else,
just stop the motor
I am pretty sure that if you use a code like that, you wont need the second limit switch. (if I am correct as to why you have it)
Now, you can convert this pseudo code into any programming language!!
Good Luck, I hope this helped!
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 20-02-2010, 10:53
FRC #2660
Does the limit switch need to be told the DIO Channel and the DIO Module?
or just the DIO Channel(In programming of course)
I believe we have been doing it right as far as the wiring goes. We're using black and white. White on the side tab and black on the NC or NO.
Unread 21-02-2010, 00:33
PriyankP's Avatar
When I did it, I just gave the pin # in my code, the port on the sidecar that get the single PWM from the limit switch.
eg.
limitswitch(13),
~ Priyank
PS. Sorry, I don't know the "proper name" of those pins on the sidecar.
Unread 22-02-2010, 00:23
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
The limit switch must be connected to a female RC(PWM) connector to Digital I/O.
This is how you declare it.
DigitalInput *limitswitch;
limitswtich = new DigitalInput(channel that you put in);
After that you should be fine. Remember that this will return you boolean statement in true or false not integers or floats.
[font="Fixedsys"][b]We Don't Hope We will.
Limit Switch Twisted eric Programming 8 22-02-2010 11:56
limit switch help program1 NI LabVIEW 10 15-02-2009 17:22
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
I've got it figured out!!! Andy Grady Rumor Mill 24 21-12-2006 19:25
gyro/accelecometer/limit switch help needed Anton Programming 4 04-02-2005 16:39
