Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 21-02-2010, 18:10
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Re: Compressor won't start
I know I should start a new post for this, but since It's the same topic, I'd rather get help from the experienced few on this topic.
We have sort of the opposite issue, my compressor starts by the use of compressor->Start(); but does not automatically turn on. I've used a multimeter to test if the switch's state changes after reaching 115psi, and it does... but the compressor never starts.
Originally, I declared the compressor on digital one and relay one:
Compressor *compressor;
then:
compressor = new Compressor(1,1);
and when that failed, I tried changing the digital switch to DIO 5 (5,1) in the code and sidecar, and still nothing!. The relay I know for sure works properly, I've tested it, but I don't know what else it could be! Also, I'm pretty sure the switch is wired correctly... black and white pwm wires on the switch. Any Idea what could the problem be?
- Meezy
ahhh Division Finalists!!
Unread 22-02-2010, 00:26
Yuan Xue Lim's Avatar
Yuan Xue Lim Yuan Xue Lim is offline
Electrical Programmer
FRC #3017 (Project Genesis)
Yuan Xue Lim is an unknown quantity at this point
Send a message via AIM to Yuan Xue Lim
then:
- Meezy
When you run the code, does the spike relay flash green or red instead of staying at orange color?
[font="Fixedsys"][b]We Don't Hope We will.
Unread 22-02-2010, 01:35
Meezy the Mentor
AKA: Rameez
no, the relay stays solid green and powers the compressor even after the pressure goes above 120psi...
I'm looking into implementing code that solely reads the value of the switch and controls the compressor without using compressor.Start(); is the switch supposed to read 1 or 0 after reaching 115 psi?
Unread 22-02-2010, 17:36
Meezy the Mentor
AKA: Rameez
still no go
We've tried two different pressure switches, and I just tried using the relay and digital input seperately...
The compressor turns on, with the relay green but never off still!
I don't know what to do, and it's odd why it's not workign right now.. any thoughts? We've even changed the relay's out...
Compressor won't start Alex_2487 C/C++ 6 12-02-2009 16:41
Wind River won't start radau C/C++ 6 19-01-2009 23:09
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
