Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 02-20-2010, 10:27 PM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
pic: A close up of the Jaguar
Unread 02-20-2010, 10:29 PM
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
no team (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: pic: A close up of the Jaguar
Just a quick question, but should you really cover the fan on the speed controller with tape? I don't know if its temporary, but i think that that could cause a problem.
Unread 02-20-2010, 10:49 PM
The tape will be removed before operation. It's a best practice to protect sensitive electronics, like the Jaguars, from metal shavings when you're working on the robot. Since we're still adding a few parts, doing some drilling and cutting, we didn't want to risk a shaving shorting something inside and burning them out.
Unread 02-22-2010, 12:20 AM
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I think this violates the rule concerning wiring PWM and CAN at the same time. I believe it must be one or the other.
Unread 02-22-2010, 01:34 AM
There are no wires going into the PWM port.
pic: Jaguar... Under the Hood MasonMM Extra Discussion 14 08-09-2008 10:03 PM
Mounting GTS - how close is close? emmell Electrical 7 02-15-2008 12:35 AM
when do the nominations close king_moleman Unsung FIRST Heroes 1 04-26-2004 03:27 PM
So close, but not close enough archiver 2001 1 06-23-2002 11:45 PM
After the parks close... Amy Beth Championship Event 23 04-16-2002 09:44 AM
