Go to Post After talking with the students on these teams I could see the light in their eyes. These were their robots! Inspired? That would be a definate YES! - Steve W [more]
Unread 21-02-2010, 17:40
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Running a Relay for a Set Time
I need to run a relay for a set amount of time while still being able to run the rest of the robot's functions. When I use the tried and true Wait() function from the Watchdog, it (as expected) halts the rest of robot operations. I have looked into separating out this function in a Task/Semaphore formation, but I'm not sure if it will solve this or exactly where to start with this (I have looked through this tutorial, but I'm still not sure where to start). What is the best way to run a function for a set amount of time while still running drive/other schmazz?
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 22-02-2010, 00:02
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
Re: Running a Relay for a Set Time
One of our programmers got it with a separate task, but what I'd suggest is starting a Timer, polling it in your loop, and as soon as the timer exceeds some length of time, turn the relay off.
Michael Andrews
Team #281 Programming Mentor
Unread 22-02-2010, 08:48
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
This is a C++ example. Its a state machine that starts with a trigger on a joystick. It even includes the 2 second lockout before the kicker can be fired again.
enum Kicker_State {
Kicker_off,
Kicker_going_out,
Kicker_out,
Kicker_coming_back,
Kicker_reload};
Timer kicker_timer;
Kicker_State kicker_state = Kicker_off;
while (IsOperatorControl())
    GetWatchdog().Feed();
    myRobot.TankDrive(left_stick, right_stick);		// drive with two sticks
    Wait(0.005);				// wait for a motor update time
    // kicker out-in actuator
    switch (kicker_state)
    case Kicker_off:
        // see if go button is pressed
        if (right_stick.GetRawButton(KICKER_BUTTON))
            kicker->Set(Relay::kForward);	// turn on
            kicker_timer.Reset();
            kicker_timer.Start();
            kicker_state = Kicker_going_out;
        break;
    case Kicker_going_out:
        // see if enough time elasped
        if (kicker_timer.Get() >= .25)
            kicker->Set(Relay::kOff);
            kicker_state = Kicker_out;
        break;
    case Kicker_out:
        if (kicker_timer.Get() >= .5)
            kicker->Set(Relay::kReverse);
            kicker_state = Kicker_coming_back;
        break;
    case Kicker_coming_back:
            kicker_state = Kicker_reload;
        break;
    case Kicker_reload:
        if (kicker_timer.Get() >= 2.0)
            kicker_timer.Stop();
        break;
}	// end operator control loop
Brian K
Team 1225 Robotics Mentor
Unread 22-02-2010, 09:51
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I'd recommend using the Notifier class. It automatically calls a callback function after a given amount of time, and works on an interrupt level so it doens't block other code until it runs.
HELP!!!EMERGENCY!!!RUNNING OUT OF TIME!!! furiousgeorge Programming 7 12-02-2009 14:05
2791 Bot running around for the first time yodameister General Forum 5 08-02-2009 04:30
Set Up Time At Regionals fatjoe3833 Regional Competitions 13 25-03-2006 00:04
Running a motor for a set time in auton Morgoth Programming 5 11-03-2003 13:59
Time is running out... archiver 2001 0 24-06-2002 00:04
