Go to Post Maybe we won't get any motors at all! Rotary Pneumatics, here we come! - Tom Bottiglieri [more]
Unread 21-02-2010, 17:38
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Has anyone had any issues with their gaming adapter?
Our gaming adapter has been pressing the security button on it's own
every time we go over the bump, the button presses itself in. It is not mounted vertically, it is mounted in a way that the button should not have momentum inward to press itself...
we were thinking about removing the button from the device completely, but then we read rule <R60>
I have no idea what we would be able to do about this!
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 21-02-2010, 21:52
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Has anyone had any issues with their gaming adapter?
Use something like vibration isolation mounts, but with more travel. Springs? foam?
Unread 21-02-2010, 22:39
I'd be curious to know whether taping the button helps. Hopefully, it would provide just enough "out-force" to keep things happy.
We had two incidents that we blamed on the button self-pushing. One held up to inspection, but the other turned out to be a separate issue. Re-orienting the bridge might help.
Unread 22-02-2010, 09:41
Kage's Avatar
AKA: Kage
we were thinking last night, and thought that maybe we would suspend it by surgical tubing...or we could borrow some of the rubber mounts from one of our old compressors...
we also need to do that to the jaguars too loo, we broke 3 jaguar fans...and now our robot sounds like a panzer tank rolling through 3 feet of plastic trash haha
"cracklecrackle bzzt click cllick click bzzt crackle!"
the fans broke off their mounts, but are still working, so they are just thrashing around inside the plastic housing... it is not a very pleasant noise
lol...
someone told us that the black jaguars may be better for shock and such...we may look into it, and order the black ones...
plus they match our robot beter! haha
Unread 22-02-2010, 11:14
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Kage - those rubber mounts for the compressors won't help you. They are specifically for dampening vibrations, and probably won't do much for sudden shocks. Further, rubber mounts of that type only work when significant weight is mounted to them. Anything lighter than their rated minimum, and it doesn't have enough mass to sufficiently deform the rubber and give you the absorption you want.
Since the Jaguars and the radio are extremely light, you won't be able to find any rubber mounts of that design that will work with them.
I would recommend tape on the security button - that should be enough to hold it out.
Has anyone else had trouble staying within the 10 second limit in autonomous? lkdjm Programming 18 12-02-2006 18:10
Has anyone recieved their Autodesk package phi.naught Inventor 29 06-12-2005 15:41
Has anyone had lack of processing power? Anthony Kesich Programming 5 26-10-2004 21:57
Has anyone else finished their entry? ComBBAT_Albrot 3D Animation and Competition 3 28-02-2002 07:27
Has anyone come up with any actual GAMEPLAY strategies? Skanker Rules/Strategy 4 30-01-2002 01:19
