Go to Post You know you've been involved with robotics too long when you see a remote-controlled traffic barrel coming up behind people and honking - and it doens't faze you. - GaryVoshol [more]
Unread 22-02-2010, 10:07
Re: Analog Out on the Cypress PSoC (enhanced modeO
Ooh Ooh! What are you planning on doing with them?
If you find something cool I'll win a bet, so please do tell!
Unread 22-02-2010, 15:11
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Thanks Greg..
I checked in the C++ documentation and I see there is SetAnalogOut()!
I did not see this before - this is cool.
The other thing - the P2 connector has a sticker of some sort on it.
It would be nice to know if we can remove it and also what type of connector plugs in to it (rather than breadboard it with individual wires).
Eric - What I have been doing is experimenting with feedback for the past few years but with each driver station changing it has been interesting!
Last year I was on the verge of converting a generic PC gamepad to a good driver station operator interface. There the fun was in using the built-in motors to generate some sort of tactile feedback.
With this Analog Output - something like that could be done, I think.
I will share with you what I come up with!
Thanks again!
Gopal
Unread 23-02-2010, 10:58
FRC #0571
One new question -
Is it possible to check if the PSoC is connected or not (using Windriver code) ?
I read the the enhanced class can get the config etc.. but if I am not using the enhanced, how can I find out if the PSoC is plugged in to the DS ?
Thanks
Unread 23-02-2010, 14:05
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
We used an analog output to drive an LED-based "bargraph". The higher the analog output, the higher the bars climb.
We use it to give our driver feedback of the current "kick strength" of our kicking mechanism.
The display is kind of small, but it is fun to watch it go depleted when fired, then climb back up to the driver's chosen power level/strength.
For the OP - we use C++ Enhanced IO class to drive this. It works great.
Here's a picture of the nearly-finished board (unpowered, sadly) - the strength meter is the rectangular white-ish object in the top middle, underneath the left-edge of the large white oval-shaped device (that's a cap-touch based slider used by the driver to set the kick strength).
http://rollingthunder.smugmug.com/20...65_HzTsD-M.jpg
Hope you can win your bet one way or another
LEDs on the Cypress PSoC mcbean Programming 4 21-02-2010 15:55
Programming the Psoc railerobotics Technical Discussion 5 18-02-2010 10:10
Analog Input tied to Accelerometer on Cypress offramp13 FRC Control System 2 05-02-2010 02:40
Programming the PSoC PortugazD.Ace Programming 19 31-01-2010 13:14
Cypress PSoc Programmer Port Selection problem Steven_585 FRC Control System 2 23-01-2010 23:06
