Go to Post FIRST was the best thing that accidentally happened to me. - Stephen Kowski [more]
Unread 21-02-2010, 14:08
Josh987's Avatar
Josh987 Josh987 is offline
That's what I say.
AKA: Josh
FRC #1565 (Think Tank Tech)
Josh987 is an unknown quantity at this point
Code problems, I think.
The code deploys without error but when I take the joystick to all forward or backwords (1, -1) or full left or right, the motors stop working alltogether. If i slowly ramp up to full left, right, forward, or backwards though it works fine. I think this is a code problems so any help is much appreciated.
Charlieeeeee, Candy Mountain
Unread 21-02-2010, 14:12
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
Re: Code problems, I think.
How are your Jags set?
Unread 21-02-2010, 14:41
Josh987's Avatar
That's what I say.
AKA: Josh
Sorry, I don't know what you mean. In the code I have opened 4 motors on jags. All the jumpers on the jags seem to be right. The wheels only stop now when i go about half power left, i can go full in all other directions.
Unread 21-02-2010, 14:46
AKA: Brandon Olsen
FRC #3219 (TREAD)
Oh, sorry. I meant to ask whether they are set to stop or coast.
Are you using any watchdog or wait delays in TeleOp?
Unread 21-02-2010, 16:03
Josh987's Avatar
That's what I say.
AKA: Josh
The jags are set to coast, no delays in the program. When the wheels stop working the jags get a slow yellow flash( think that means no servo connection.)
Unread 21-02-2010, 17:50
Josh987's Avatar
That's what I say.
AKA: Josh
So i have worked it down to this problem, when i have all 4 motors at full forward, the crio stops suppling power to the digital sidecar( the 5v light turns off). If i then toggle the enable, disable on the drivers station the digital sidecar turns on and then stops when at full power. We used a new battery and changed the side car.
Unread 21-02-2010, 18:24
Michael Fadaie Michael Fadaie is offline
FRC #3393
Michael Fadaie is an unknown quantity at this point
Our team had the same problem. Is the game adapter hooked up to the 12v spot on the pwer distribution board?
Unread 22-02-2010, 10:48
Josh987's Avatar
That's what I say.
AKA: Josh
The game adapter is hooked up correctly, but we had it connected through the ethernet cable to the crio (Before it's asked, yes it was in port 1). I have tried multiple different codes, tank/arcade 4 wheel have the problem, even when i tried using 2 two wheel arcade drives the same problem occurred. I am starting to think this is a electrical problem not code so I might post it there.
Unread 22-02-2010, 11:20
Josh987's Avatar
That's what I say.
AKA: Josh
So the plot thickens, we have just found out that if you unplug any 2 pwm cables (that are connected to jags) the motors are able to go full power and the digital side car doesn't lose the 5v signal from the crio.
Unread 22-02-2010, 11:42
Disconnect all the cables from your digital sidecar, including the 37 pin cable, but keep the power cable plugged in. When you do this, do all 3 power LEDs shine brightly? If not, you have a problem with the power cable.
I'm a little concerned when you say the digital sidecar looses it's 5v signal from the cRIO. Can you show some pictures of how its wired?
Unread 22-02-2010, 14:51
Josh987's Avatar
That's what I say.
AKA: Josh
No, all 3 lights don't show up.
Unread 22-02-2010, 16:27
That's conclusive. You need to correct the 12v power input to the Digital Sidecar. It should come from a 20A circuit breaker on the Power Distribution board. Make sure the wires are stripped the proper length so that the Wago connectors (red/black and white) bite down on the bare wire.
Unread 22-02-2010, 22:19
Josh987's Avatar
That's what I say.
AKA: Josh
Yepp that was the problem, we had the wires reversed.
Thanks very much for all the help.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Array problems( i think....) Andrew Blair Programming 10 22-09-2005 19:57
