Go to Post We do not pursue awards, we pursue greatness and the awards follow. - Sunshine [more]
Unread 02-13-2010, 10:09 PM
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Re: Slow Dashboard Images SOLUTION
Joe you were right. It had nothing to do with the camera. Someone had commented out the Continuous functions in IterativeRobot and I forgot that I had uncommented them. We started again from code that we new worked and when I uncommented them the problem returned - slow downloads and slow execution times. We commented them out again and the problem has not returned (knock on wood). I've seen at least one other post about these same functions causing problems.
Steve
Unread 02-21-2010, 05:54 PM
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
WOW thanks so much this fixed ours!
Rob Self-
Cyberhawks Team 706
Hartland, WI
Our breakaway bot in action (13-3-1): Team 706 in action
Unread 02-22-2010, 12:35 PM
anyheck anyheck is offline
FRC #2242 (Cougars)
anyheck is on a distinguished road
We just need a live camera on the dashboard for the drivers to see when they have the ball in the shooter.
I commented out or deleted all of the vision code on the robot other than in Begin.vi and modified the dashboard to just be not more than the "image get" vi.
It works quite well and we're getting 20+FPS on the dashboard with a fraction of a second lag.
Camera Solution ProgrammerMike7 Programming 12 02-02-2010 10:32 AM
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04 AM
the solution focus fanatic Chit-Chat 8 01-18-2006 03:36 PM
How slow is too slow? Joe Ross Rules/Strategy 23 10-12-2004 08:23 PM
