Re: camera problem
Have you connected the camera directly to your computer and tried to access it via a web browser as described in the control system manual? Did you run the camera setup utility to add the "FRC" user (with a password of "FRC")? Did anyone change its IP address to something other than the camera's default?
The green light was the vision target in 2006 and 2007. This year the target is just a black circle with contrasting white on the inside and outside. The camera should have no effect on any other sensors (like encoders) or actuators (like Jaguars or Spikes). |
| Camera problem | ijk90825 | Technical Discussion | 1 | 28-01-2009 01:35 |
| Possible camera problem? | Robot-pineapple | Technical Discussion | 6 | 13-01-2009 09:00 |
| Camera Problem | ta1234 | Programming | 1 | 29-01-2007 09:38 |
| camera problem | miscar | Programming | 2 | 23-01-2005 12:06 |
| Camera Problem | n_0163 | Electrical | 3 | 14-01-2005 21:10 |
