Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
Unread 22-02-2010, 13:15
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
R-63 - wiring limit switches to Jaguars
According to R-63, we can only connect things to the coast/brake and pwm ports. Does this mean we can not connect anything to the forwards/backwards limits? If so, does that mean the jumpers have to go?
<R63-B> PWM configuration: If the Jaguar speed controller is controlled via PWM communications, the PWM port on the Jaguar speed controller must be connected directly to a PWM port on the Digital Sidecar with a PWM cable. No other devices may be connected to these PWM ports. No other devices may be connected to any other ports on the Jaguar speed controller with the exception of connection to the coast/brake port.
Unread 22-02-2010, 13:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: R-63 - wiring limit switches to Jaguars
One would assume that they were not including jumpers in the definition of "devices" given that the Jaguars will not function without them.
Unread 22-02-2010, 13:22
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I would Q&A this if I were you.
___________________
- Tennyson, Ulysses
Unread 22-02-2010, 13:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Ruling the jumpers illegal is exactly the same as ruling PWM control illegal. Without the jumpers the Jaguar will assume the limit has been reached and will not output anything.
Unread 22-02-2010, 13:35
FRC #1325
Yes but the next question is can we still wire limit switches to the jaguars in the places where those jumpers would go?
Unread 22-02-2010, 13:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You could Q&A that if you want. but I am fairly certain (like 99%) that the answer will be no. Common sense says that a jumper is not a device and a limit switch is.
Unread 22-02-2010, 13:55
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Common sense =/= rules.
Just Q&A it
___________________
- Tennyson, Ulysses
Unread 22-02-2010, 14:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
While I agree that the Q&A would be the only way to get an official answer, what I am suggesting is that you not waste both your time and the GDC's time asking this question.
When reading these rules, please use technical common sense (engineering thinking) rather than “lawyering” the interpretation and splitting hairs over the precise wording in an attempt to find loopholes.
My technical common sense says that a limit switch is a device. If you think there is any chance of it being ruled otherwise and you have the time to wait and see what the GDC says, definitely go to the Q&A with it.
Unread 22-02-2010, 23:15
Starting with R60...
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
The Jaguars come with jumpers in place. If using the PWM input the jumpers musts be in place for correct operation.
wiring the 2010 digital limit switches theyshalllive Electrical 6 19-02-2010 20:17
Limit switches to Jaguars Team1710 Electrical 4 15-02-2010 19:09
Limit on number of Jaguars? Joe6391 Electrical 5 03-02-2010 23:19
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
limit switches stephenthe1 Programming 28 11-05-2005 16:37
