Go to Post When you open of CD and you see your very own quote up top, and can't decide if it's a really awesome or "Well...this is awkward..." moment - CalTran [more]
Unread 02-22-2010, 01:37 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Code download issue
Yes, you've got the right basic idea. It's simply an issue of the distance between your code and the O/S or libraries that you're calling. Because VxWorks 6.x uses a best-fit memory allocation scheme, the size of your code will be compared to the free memory regions (in a VxWorks console shell, issue "memShow(1)" to see the gory details) and your code will be placed in the memory area where it fits with the least amount of memory fragmentation. So, if your code was smaller in size, this problem may not have surfaced for quite some time (like the finals in Atlanta ;-).
Good luck,
Mike A.
Delay of Code Download phencer42 Java 5 01-22-2010 03:57 PM
Issue deploying Code rudun Java 5 01-18-2010 09:24 PM
Cannot Download Code mandalorethx C/C++ 5 01-15-2010 12:44 PM
Can't Download Code nickmagus Programming 1 01-05-2009 05:52 PM
Code Download via Serial Issue phrontist Programming 9 02-08-2005 05:32 PM
