Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 22-02-2010, 14:35
hoffman01 hoffman01 is offline
hoffman01 is an unknown quantity at this point
Unhappy cRIO problems
Before I start this thread I need to say that I do not know what forum to place it under... it might even fit under programing?..
When I turn the robot on the cRIO does not turn on as well. There is also a medium pitched buzzing sound coming from the robot that was not there before.
When the Ethernet cable is tethered to the driver station the light on the cRIO will come on for less than a second - then go off.
When a digital sidecar is plugged up into the cRIO NO lights are lit up.
Everything is wired correctly. Also, everything was working last Friday when I downloaded some code into it. I did not come to school Saturday- so I will ask my team if they changed anything...
Do we have a bad/dead cRIO?!??
Unread 22-02-2010, 15:49
Re: cRIO problems
Please help as there is not much time till bag/tag!!
Unread 22-02-2010, 15:54
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: cRIO problems
Have you checked your battery level? Sounds like a low voltage lockout. Could also be a short - check your chassis for metallic debris.
Unread 22-02-2010, 15:56
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
Re: cRIO problems
That's my recommendation, along with the battery change. We had a short because of metal shavings that fell into the power distribution board. We used a shop vac and then a compressor to get them out.
Unread 22-02-2010, 16:13
Wink Re: cRIO problems
Thanks everyone for your help !!
It turns out two batteries we had not fully charged. The new battery that was fully charged worked.. I feel really stupid. Thanks again!
cRio problems. darkshark0159 Electrical 4 21-02-2010 21:56
Crio problems Twisted eric Programming 9 21-02-2010 01:33
cRio problems blazingshadow Programming 2 31-01-2010 17:18
cRio Problems tanguma26 Inventor 3 25-01-2010 13:19
cRio problems tanguma26 Programming 4 21-01-2010 21:09
