Go to Post Remember that though we come from different backgrounds and x, y, z, we are all on each other's side. We want people to love STEM, and think FIRST is a great tool to fulfill that desire. - PayneTrain [more]
Unread 22-02-2010, 15:49
Bart Bart is offline
FRC #2625
Bart is an unknown quantity at this point
Angry Camera Initialization Lags robot
Hi,
Whenever I try to initialize the camera using:
AxisCamera &axisCam = AxisCamera::GetInstance();
The robot starts to lag (The watchdog dies even with a 500ms timeout), and worst of all, the robot STILL does not send video to the dashboard
Yes we have the latest dashboard, crossover cable, camera set up properly. Any suggestions?
Unread 22-02-2010, 16:26
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
Re: Camera Initialization Lags robot
did you give the camera time to boot up fully before trying to use it in your code? if not it can hang the robot really easily, try adding a few waits before and after it
Unread 22-02-2010, 16:54
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Where are you putting that in the code? I have it in Robot Init and it does not seem to slow anything down, and I get video. I have also noticed that the camera delays more with a low battery, so be sure to keep batteries fresh.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 22-02-2010, 18:16
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
One thing we found about the camera is that if you don't have communication with it, the GetInstance will take some time then timed out. The cause for us was that we used a wrong ethernet cable. You need a cross-over cable for the camera. We knew about the cross over cable requirement but we didn't realize the cable we grabbed wasn't cross-over. So make sure you label your cable correctly if you make your own.
Unread 22-02-2010, 21:32
FRC #2625
Got it working, I changed the following:
Put camera init code in teleop, that way it waits a bit before starting, and I changed the camera subnet mask to 255.0.0.0
Unread 24-02-2010, 00:04
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
yeah, if the camera code hasn't finished we found the same issuse of timeouts and other bad things happening to the robot (took a whole 1.5 hours of our testing time to figure out it was the camera ). The problem seems to be WPILib's internal handling of errors and their lack of a limiter on number of errors per second. It looks like the I/O gets overwhelmed and code slows down
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Camera Declaration/Initialization scolbertrocks C/C++ 3 22-02-2010 07:26
ADC Initialization problem Shomron1690 Programming 4 14-02-2007 18:06
???Abnormal Camera Initialization???????????? cdennisxlx2 Programming 4 07-11-2006 00:45
Reciever Initialization problem PuiChi Programming 1 26-01-2004 23:54
Master uP Initialization Routine Ulibrium Technical Discussion 5 24-01-2002 16:43
