Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 22-02-2010, 14:16
Generator of Entropy
FRC #2973 (The Mad Rockers)
Min speed on the CIMs?
Has anyone tested the CIMS to see what minimum speed they are capable of at no load (where the PWM frequency voltage is too low to turn the motor), or at any other known load where I can scale the performance curve?
Unread 22-02-2010, 14:47
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: Min speed on the CIMs?
0RPM is the slowest I can get it to rotate.
Now then... I have been able to get them to spin very slowly, but I don't know the specific RPM. It all really depends on the motor and how broken in it is, or if it has any bad sleeves/bearings or whatever it has. When I was just learning C, I would bump up the PWM value from 127 until the motor would start to turn with the 884 and the IFI controller. I know the minimum throttle for the 884 is 3%, I'm unsure what it is with the Jaguar, but I doubt the CIM will turn with a 3% throttle anyway.
I probably haven't helped you a bit, but I figured I would give you as much information as I could.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 22-02-2010, 15:03
Assuming what you are asking for is open-loop motor performance curves (as opposed to closed-loop speed control capability of the motor controller), since you mentioned PWM (and not CAN)...
Note sure if this answers your question, but here is a link to CIM datasheet which has
the motor performance curves (speed/current/torque):
http://lib.store.yahoo.net/lib/yhst-...otor-curve.pdf
See attached GIF
Unread 22-02-2010, 15:06
This thread may be of interest: http://forums.usfirst.org/showthread.php?t=10182
Unread 22-02-2010, 15:28
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
While testing the CAN-bus connected to the PC, we got a CIM motor with gearbox (~9:1) to spin with 6% output.
Not very useful data, but better than no data...
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 22-02-2010, 16:17
Thanks, that gets me in the ballpark. I know at some point the voltage pulse is just not long enough to drive the motor but I wasn't sure how low it would go; 6% is impressive, since the profile of the Jag's looks pretty linear (from Eric's post).
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
Min/Max Problems? AndyKK2 Programming 2 16-02-2003 21:12
is it really just 2 min? archiver 2001 1 23-06-2002 23:05
FYI: 15-30 min downtime Brandon Martus Announcements 0 01-03-2002 22:57
