Go to Post I've never seen a spam bot edit posts before - Vikesrock [more]
Unread 22-02-2010, 17:33
SeanTeags's Avatar
SeanTeags SeanTeags is offline
Tigger
AKA: Sean
FRC #1403 (Cougar Robotics)
SeanTeags is an unknown quantity at this point
Alternate Light Help
Hi guys,
We're having trouble with the rules. We were wondering if we were allowed to add another light to the system that turns on when a limit switch is activated. If you could point us to the rule and explain it to us, we would be really grateful.
Thanks!
Unread 22-02-2010, 17:40
EricH EricH is online now
Re: Alternate Light Help
Where do you want to mount the light?
Also note that there are very few restrictions. The main one would be in <R02-A> and <R02-C>; if you're putting it on the operator panel, you'll probably be wanting to simply use the Classmate's dashboard.
Unread 22-02-2010, 22:08
DonRotolo's Avatar
Back to humble
FRC #0832
For the most part, you should have no problems putting such an indicator light onto the robot. Unless it draws just a few milliamps, you'll need a spike to control it though. You cannot use the pneumatic solenoid module, even though it would be perfect, because of <R65>
Help--Program Light Stuck NinJA999 Programming 7 07-02-2008 14:13
HELP WITH THE LED SIGNAL LIGHT Bre92 Electrical 2 27-01-2008 22:31
help-Camera doesn't see the light steve d Programming 1 18-02-2007 15:30
Camera Looks away from light???? Help? coldfusion1279 Programming 7 31-01-2007 11:34
Light Sensor Type, Please Help! Alexander McGee Electrical 7 20-11-2004 21:48
