Go to Post I actually love and am very thankful for what all these amazing engineering role models put into this program year in and year out. - Bill Gold [more]
Unread 22-02-2010, 17:03
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
Antenna Switch?
HI
Are we allowed to change the antenna on the access point? our communication sucks without it.
Thanks
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 22-02-2010, 17:11
Racer26 Racer26 is offline
Re: Antenna Switch?
You wont be using the access point on the field. At competition you will plug your controls into a wired network at the field, which your robot will connect to via wifi.
Unread 22-02-2010, 17:13
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Re: Antenna Switch?
no access point at all? but.. I only thought that you still use the access point but not the router...
so how does the cRio get the orders from the DS?
Unread 22-02-2010, 17:15
Re: Antenna Switch?
You're talking about the on board wireless gaming adapter (bridge) (WGA600N or WET610N)?
Those don't HAVE external antennae, theres no way for you to change it.
Unread 22-02-2010, 17:18
May_Walter's Avatar
Artemis #3083
FRC #3083 (Artemis)
Re: Antenna Switch?
ok, so listen
We're from Israel so we have different access points... what I'm asking is - is there a rule against changing the access point / ruoter's antenna?
Unread 22-02-2010, 17:27
Re: Antenna Switch?
Ah. You would have to ask FIRST that. Its unlikely anyone here will know.
Unread 22-02-2010, 17:37
EricH EricH is online now
Re: Antenna Switch?
If it involves opening the equipment, see the following:
<R60> The control system is designed to allow wireless control of the ROBOTS. The Classmate PC, FirstTouch I/O module, cRIO-FRC, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
H. Wires, cables, and signal lines may be connected via the standard connection points provided on the devices.
I. Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT.
(bold is my emphasis)
I'd say that's most likely a no to changing the antenna. Ask in Q&A, though; you never know.
Antenna position Torboticsmember Rules/Strategy 2 16-02-2008 11:18
eplacement Radio Modem Antenna - Chrome neoshaakti Kit & Additional Hardware 3 05-02-2008 16:45
Oh no... a broken antenna... Japper General Forum 8 27-01-2007 14:34
i broke my vex antenna colin340 VEX 7 30-11-2006 14:05
Pringles Can Wi-Fi Antenna MattK Chit-Chat 4 07-11-2002 20:44
