Re: Diagnostics tab causes relay troubles
The problem seemed to be fixed with a firmware update to the Driver Station. Problem solved. Thanks guys.
| Where is the design tab located? | Abole | Inventor | 9 | 17-02-2010 13:44 |
| No robot diagnostics | unobtainium-42 | C/C++ | 3 | 31-03-2009 09:50 |
| CMUcam2 Serial Port Diagnostics | Kevin Watson | Programming | 13 | 18-02-2006 15:05 |
| Breaker Panel Diagnostics | dm0ney | Programming | 4 | 29-03-2005 19:00 |
| TAB command in Pbasic | virusmirusne | Programming | 11 | 25-01-2003 02:51 |
