Go to Post Fool me once? Shame on you... Fool me thrice? I'm just a wishful thinker :( - Bill Gold [more]
Unread 22-02-2010, 18:30
superstretch superstretch is offline
FRC #0417
superstretch is an unknown quantity at this point
Solenoid Code Does Not Work!
We are using 12volt solenoids hooked up through the solenod break out. Everything in the code so far works besides the solenoids. The lights on the module don't light up either. The solenoids work and the pistons fire when the buttons are pressed manually.
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class MyCode : public SimpleRobot
RobotDrive *myRobot; // robot drive system pointer
Joystick *stick; // arcade drive joystick pointer
DriverStation *ds; // driver station object
Solenoid *s1;
Solenoid *s2;
Solenoid *s3;
Solenoid *s4;
Solenoid *s5;
Solenoid *s6;
Compressor *c;
bool btn1state;
bool btn2state;
bool btn6state;
bool btn7state;
bool quickReleaseState;
bool resetPistonState;
public:
* Constructor for this robot subclass.
* Create an instance of a RobotDrive with left and right motors plugged into PWM
* ports 1 and 2 on the first digital module.
MyCode(void)
ds = DriverStation::GetInstance();
myRobot = new RobotDrive(1, 2); // create robot drive base
stick = new Joystick(1); // create the joystick
s1 = new Solenoid(1); // allocate the Solenoid objects
s2 = new Solenoid(1);
s3 = new Solenoid(1);
s4 = new Solenoid(1);
s5 = new Solenoid(1);
s6 = new Solenoid(1);
c = new Compressor(1,1);
c->Start();
GetWatchdog().SetExpiration(5.0);
//AxisCamera &myCamera = AxisCamera::getInstance();
* Drive left & right motors for 2 seconds, enabled by a jumper (jumper
* must be in for autonomous to operate).
void Autonomous(void)
GetWatchdog().SetEnabled(false);
for (int j = 0; j<3; j++)
// myRobot->Drive(0.5, 0.0); // drive forwards half speed
s1->Set(true); //activate quick release retract
Wait(1.0);
s1->Set(false); //for 2 seconds
s3->Set(true); //activate reset piston extend
Wait(1.0);
s3->Set(false);
s2->Set(true); //activate quick release piston extend
Wait(1.0);
s2->Set(false);
s4->Set(true); //activate reset piston retract
Wait(1.0);
s4->Set(false);
myRobot->Drive(0.0, 0.0); // stop robot
GetWatchdog().SetEnabled(true);
* Runs the motors under driver control with either tank or arcade steering selected
* by a jumper in DS Digin 0. Also an arm will operate based on a joystick Y-axis.
void OperatorControl(void)
btn1state = 0;
btn2state = 0;
btn6state = 0;
btn7state = 0;
quickReleaseState = 1; //quick release piston is extended
resetPistonState = 0; //reset pistion is retracted
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot->ArcadeDrive(stick); // drive with arcade style
if (stick->GetRawButton(1) && !btn1state) //button is pressed but not being held
btn1state = 1; //button is being pressed
Wait(1.0); //for 2 seconds
s1->Set(false); //reset state
s1->Set(true); //activate reset piston extend
Wait(1.0);
s3->Set(false); //restet state
Wait(1.0);
s2->Set(false); //reset state
Wait(1.0);
s4->Set(false); //reset state
else if(!stick->GetRawButton(1) && btn1state) //button is not being pressed
btn1state = 0; //reset state
if (stick->GetRawButton(6) && !btn6state)
btn6state = 1;
if (quickReleaseState)
s2->Set(false);
quickReleaseState = 0; //quick release piston is retracted
else
s1->Set(false);
s2->Set(true); //activate quick release extend
else if(!stick->GetRawButton(6) && btn6state) //button is not being pressed
btn6state = 0; //reset state
if (stick->GetRawButton(7) && !btn7state)
btn7state = 1;
if (!resetPistonState)
s4->Set(false);
s3->Set(true); //activate reset extend
resetPistonState = 1; //reset piston is extended
else
s3->Set(false);
s4->Set(true); //activate reset retract
resetPistonState = 0; //reset piston is retracted
else if(!stick->GetRawButton(7) && btn7state) //button is not being pressed
btn7state = 0; //reset state
START_ROBOT_CLASS(MyCode);
What is wrong with my code? Please help me!
Unread 22-02-2010, 18:45
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Solenoid Code Does Not Work!
You posted long code without indentation. Use the "#" button the next time. I didn't look through the entire code because of the readability but for the first mistake, you were creating six solenoids on the same DO channel (channel 1)???
Unread 22-02-2010, 18:58
FRC #0417
well, thats embarrasing... sorry
also, thanks for the tip on posting code
Edit: if i repost the code with proper format would you mind giving it a look over for any other obvious mistakes?
Unread 22-02-2010, 19:05
FRC #0417
I suppose that also explains the error:
Fatal error "Attempting to reuse an allocated resource" in Allocate() in C:/WindRiver/workspace/WPLib/Resource.cpp at line 76
that I was getting in the diagnostics tab
Unread 22-02-2010, 19:08
mikets's Avatar
Software Engineer
Yep.
Unread 22-02-2010, 19:10
FRC #0417
My code with formatting preserved:
#include "WPILib.h"
	Solenoid *s1;
	Solenoid *s2;
	Solenoid *s3;
	Solenoid *s4;
	Solenoid *s5;
	Solenoid *s6;
	Compressor *c;
	bool btn1state;
	bool btn2state;
	bool btn6state;
	bool btn7state;
public:
	MyCode(void)
		s2 = new Solenoid(2);
		s3 = new Solenoid(3);
		s4 = new Solenoid(4);
		s5 = new Solenoid(5);
		s6 = new Solenoid(6);
		c->Start();
			Wait(1.0);
			Wait(1.0);
			s3->Set(false);
			Wait(1.0);
			s2->Set(false);
			Wait(1.0);
			s4->Set(false);
		btn1state = 0;
		btn2state = 0;
		btn6state = 0;
		btn7state = 0;
				Wait(1.0);
				Wait(1.0);
				Wait(1.0);
				btn6state = 1;
					s2->Set(false);
				else
					s1->Set(false);
				btn7state = 1;
					s4->Set(false);
				else
					s3->Set(false);
thanks for any and all help
Unread 22-02-2010, 19:27
mikets's Avatar
Software Engineer
Assuming your code is reflecting the connection of channels accurately, the code looks find. However, without knowing what the solenoid configurations are, I would guess there is one more mistake.
				s1->Set(true); <<< Should this be s3???					//activate reset piston extend
				Wait(1.0);
				Wait(1.0);
				Wait(1.0);
Unread 22-02-2010, 19:38
FRC #0417
ooh, nice catch, thank you.
Gah still 12hours till i can test my code again!
Unread 23-02-2010, 10:30
Mageofdancingdr's Avatar
Mageofdancingdr Mageofdancingdr is offline
Mageofdancingdragons
AKA: DJ Hoffman
FRC #0599 (Robodox)
Mageofdancingdr is an unknown quantity at this point
also, one of the simplest ways to mess up that pneumatics board is double checking that it's in slot 8 on the CRIO and using the constructor that specifies slot as well as channel, for code clarity mostly.
3.1415926535897932384626433832
Solenoid code not working ssmith2 NI LabVIEW 6 03-02-2010 10:11
Eclipse does not work jasonpeinko Programming 7 22-02-2008 09:51
Autonomous mode does not work Sunny Programming 9 16-01-2008 15:31
Arcade Mode (12) does NOT work jakk Programming 2 10-07-2006 19:27
Chaos theory does not work!!!!! S9ar7acu3 General Forum 3 09-02-2003 11:46
