Re: How to wire Air Compressor's spike relay?
I'm probably the last person to answer this question, so my answer carries all the authority of "something I read on the Internet". But I do have a source: http://robotics.hideho.org/data/firs...Controller.pdf on page 16 states, "The Solenoid Breakout
● Has 8 solenoid outputs. ● Completely eliminates the need for Spikes for pneumatics. ● Can drive 12 Volts at up to 0.75 Amps per output." So you might not need to use a Spike. |
| how to connect the spike to the sidecar relay | executionR | Pneumatics | 5 | 22-02-2010 22:13 |
| How to connect the 12v solenoid to the cRIO and spike relay? | hannigan | Pneumatics | 3 | 13-02-2010 09:21 |
| Relay (Spike) | elbuo | Electrical | 2 | 09-02-2009 20:36 |
| Spike Relay Wire Gauge | sparrowkc | Electrical | 7 | 12-02-2008 14:26 |
| Spike Relay Input | nwagers | Electrical | 3 | 16-07-2002 22:23 |
