Re: phantom commands occuring
You are able to send commands in disabled mode. You aren't supposed to be able to run outputs in disabled mode. However, if you latch some command in disabled mode which causes an output to run in enabled mode, that is perfectly OK.
It was hard for me to tell if that is what you are referring to, or whether you were actually able to run outputs in disabled mode. |
| Birthdays occuring during this years Championship? | Ashley Christine | Championship Event | 12 | 12-04-2008 18:47 |
| Commands | Barchechath | Programming | 7 | 05-02-2007 18:55 |
| at commands in c++ | daroch | Programming | 1 | 04-03-2005 01:01 |
| Phantom of the Opera | Shu Song | Chit-Chat | 3 | 02-03-2005 01:24 |
| Interrupt not occuring. | devicenull | Programming | 4 | 18-02-2005 21:46 |
