Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 22-02-2010, 22:34
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Camera Lag After the Mandatory Updates
Hi all,
My team applied the mandatory update last night to our cRIO and the Driver Station. After the update, we tried running our program to observe the "improvement in performance in vision processing"(if I remember correctly from previous threads in delphi). However, our program lagged significantly enough to interfere with continuous driving. I tried changing the resolution on the camera and other stuff to eliminate the lag, but I couldn't eliminate the latency entirely(yes, with lower resolution I was able to smooth out the latency between the controller and the robot, but it didn't really help).
Is there any hotfix for this issue? Or is it just our team having this problem?
p.s. We didn't change anything on our program... So, I don't think it's our program problem...
Unread 22-02-2010, 22:41
rath358's Avatar
rath358 rath358 is offline
AKA: max
FRC #0093 (NEW Apple Corps)
rath358 is on a distinguished road
Re: Camera Lag After the Mandatory Updates
You are not the only ones. There are several threads about the problem, but no solution YET. If I am remembering things correctly, someone from NI is looking into it.
Unread 22-02-2010, 22:44
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our team has fought with this as well.
One thing we did was take out some of the camera processing which helped quite a bit. So far, we are only using the camera for basic visual to help the driver aim.
Unread 22-02-2010, 22:47
bls0620's Avatar
We are doing the same thing right now.... only using the camera for drivers to aim
Unread 23-02-2010, 22:18
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Our team solved this by downloading a custom Dashboard and using that instead. It removed a few of the graphs that were included in the latest update, but we didn't use those anyways, and we now have almost live video feed, which is amazing.
Thank you to teams 174, 188, 191, 610, and 1551 for some great matches in the FLR finals!!
Unread 23-02-2010, 22:51
Elean Atencio's Avatar
Elean Atencio Elean Atencio is offline
Software Mentor
AKA: Elean-1065
FRC #1065 (The Moose)
Elean Atencio is an unknown quantity at this point
how do you download a custom Dashboard?. Our team is having a tough time with camera lag. Before the update it was like 2 seconds but after the update it went up to 5 seconds. All we are doing with the camera is calling the getinstance in the constructor.
Unread 23-02-2010, 23:44
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
To use a custom dashboard, you can either write one yourself (in LabVIEW) or download someone else's custom one. I believe the one the poster above you was referring to was this. To install it, take the files in the zip folder and copy them to C:\Program Files\FRC Dashboard (MAKE A BACKUP FIRST!!!). It should automatically load the new dashboard when driver station is run.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 24-02-2010, 11:31
How to Create Your Own Dashboard:
  1. Exit the Driver account to close everything (Setup tab -> Exit)
  2. Login to the Developer Account
  3. Use LabVIEW and create a new Dashboard project.
  4. You'll then need to create an exe
    1. Right click on Build Specifications -> New -> Application (EXE)
    2. In the Popup:
      1. "target filename" - change the name to Dashboard.exe
      2. Change the Destination Directory to "C:\Program Files\FRC Dashboard"
    3. Tell it where to begin:
      1. In the left list click on "Source Files"
      2. Click on "Dashboard Main.vi"
      3. Click on the right pointing arrow that will highlight
      4. You should see Dashboard Main appear on the right hand side under "Startup VIs"
    4. Click on "Build" at the bottom to create your exe
  5. Login to the Driver account to start up the new dashboard and see if it works.
Unread 24-02-2010, 12:06
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We've customized our dashboard a bit as well, and we even have our own custom camera code. It was pretty cool Sunday night sitting in the programming room watching people work on the robot.
Unread 24-02-2010, 15:43
rath358's Avatar
AKA: max
Turn off automatic error logging on the robot.
search for this thread to see how:
"Turning off automatic error logging in LabVIEW may improve loop timing "
(no link so this appears faster)
Camera Lag Jonanin FRC Control System 3 05-02-2010 11:29
Camera lag...again ideasrule Programming 5 02-02-2010 13:09
Camera lag solution ringo115 Programming 11 31-01-2010 22:05
Camera Lag tutkows1 Java 1 27-01-2010 00:20
Camera Lag jmanela NI LabVIEW 6 25-12-2009 08:48
