#11
Re: Festo double solenoid problems
A simple check for 12 volt valves is to wire externally a 9 volt transistor battery. You should see the led light and you should hear the solenoid click even with no air. Sometimes it is just a bad valve.
| Festo Solenoid | lostkhaos | Pneumatics | 5 | 21-01-2010 10:15 |
| Festo Solenoid Doesn't Work | frank.pendzich | Pneumatics | 20 | 11-02-2009 20:33 |
| Festo Single solenoid | JP_1163 | Pneumatics | 4 | 24-02-2006 15:07 |
| Festo solenoid wiring? | computhief263 | Pneumatics | 1 | 15-02-2004 12:25 |
| festo solenoid | maxgebhardt | Pneumatics | 19 | 21-01-2004 23:06 |
