Go to Post I respect what you have to say and I ask that you do the same for me. - Andrew Schreiber [more]
Unread 22-02-2010, 19:00
tait tait is offline
FRC #2564
tait is an unknown quantity at this point
Festo double solenoid problems
My team is having a problem; we are using the festo that came in the 2010 kop and we can't get it to fire remotely. Manual override works fine, we also connected it to the 24v output in the cRIO, but still the piston won't fire remotely. Any ideas? Also, we are using labview. Any and all help on this subject would be greatly appreciated.
Unread 22-02-2010, 19:35
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Festo double solenoid problems
Sounds like the same problem that a team here in Hawaii was having.
We gave them our Festo, but never followed up with them.
I'll ask them to follow up.
Hopefully, you get an answer before we do.
Unread 22-02-2010, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
Is one of the 8 green lights on the solenoid module on? If not, then your code is not commanding the solenoid on.
Unread 22-02-2010, 22:18
FRC #2564
No, none of the green lights are on. We are setting the solenoid set vi with a single button from the joystick. Can you please help me fix the code, or give me an example screenshot?
Unread 22-02-2010, 22:22
kavisiegel kavisiegel is offline
FRC #0061 (The Shifters)
kavisiegel is an unknown quantity at this point
Here's some sample code
www.team61.com
Unread 22-02-2010, 22:23
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Do you have the bumper wired for power from the PD?
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 22-02-2010, 22:26
FRC #2564
Thanks, i'll let you know if it works.
What is the DIO for in the begining?
Unread 22-02-2010, 22:27
FRC #2564
Yes, its already connected to the 24v output in the PD
Unread 22-02-2010, 22:29
Ignore that, it's our limit switch for our arm so we don't lift too high. I meant to delete it in that screen shot.
Our big problem was that we weren't initiating one side with true or false, so they both remained false no matter how many times we tried to flip them. Hope it helps.
www.team61.com
Unread 22-02-2010, 22:37
FRC #2564
your example shows us the true value of the boolean, is it possible that you could show us the false? Much appreciated
where did you get the execute on rising edge?
Unread 22-02-2010, 22:44
On initiation, or in the second VI?
On initiation you want one of the 2 sides to be set to true. Wherever you want the default state of that piston to be, set it to true.
In the second VI, what it does is read one of the 2 sides. Specifically, the arm minus side. If that's true, it sends that true to the arm plus side and inverts it to a false that it sets its self to. Basically, all it does is switch sides.
The execution on rising edge, that was posted in the LabVIEW form a week or so ago. The arrow that looks like an equals sign is called "Implies" and can be found in the boolean group of functions
www.team61.com
Unread 22-02-2010, 22:48
waialua359's Avatar
AKA: Glenn
Another team here had the same problem and checked the voltage. The wiring was poor where they were getting 23.x volts. It was enough to turn on the LED but not enough to fire. Also, do you have active pressure, otherwise, I believe it wont even work or click.
FRC #2564
did you guys wire the signal on the solenoid connection?
Unread 22-02-2010, 22:55
A simple check for 12 volt valves is to wire externally a 9 volt transistor battery. You should see the led light and you should hear the solenoid click even with no air. Sometimes it is just a bad valve.
Unread 22-02-2010, 23:03
FRC #2564
I dont have a nine volt battery but thanks for the idea. we wired the red cable with the red and the black with black. Do we have to wire the black one with a signal and the red one to ground? The watcdog is not ffed at some point in the previous code. What is the watchdog; what purpose does it have?
Festo Solenoid lostkhaos Pneumatics 5 21-01-2010 10:15
Festo Solenoid Doesn't Work frank.pendzich Pneumatics 20 11-02-2009 20:33
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
