Go to Post You get to see great matches at the Championship event regardless of a people's choice event. - Yan Wang [more]
Unread 22-02-2010, 12:00
Jordan2389Diaz's Avatar
Jordan2389Diaz Jordan2389Diaz is offline
Grant me your power...Verto
FRC #2389 (Pirate Robotics)
Team Role: Tactician
Jordan2389Diaz can only hope to improve
Burnt Fuses
My team's CRio spike is burning fuses; does anybody know how to fix the problem.
Lord is my Shepherd I shall not want-Psalms 23
Unread 22-02-2010, 12:03
Racer26 Racer26 is offline
Re: Burnt Fuses
...The cRIO isn't supposed to be on a Spike.
EDIT: There is no team-accessible fuses/circuit breakers in the path to the cRIO. There is an internal fuse inside the cRIO that you're supposed to send it back to NI for repair, and there may be one in the PD board. The cRIO is to be powered from the 24V output on the bottom of the PD board.
Unread 22-02-2010, 12:31
Re: Burnt Fuses
What kind of motor did you attach to the Spike?
Unread 22-02-2010, 12:36
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Burnt Fuses
You are allowed to replace the fuse on the Spike with a Snap-Action circuit breaker of 20 amps (no more), the same kind used by the PD board.
You cannot use CIM or Fisher-Price motors on Spikes, they draw too much current.
The 555 and Window motors are fine for Spikes. The compressor uses one too. You should replace the fuse on the Spike for the compressor with a breaker, the starting current of the compressor is enough to cause burnt fuses.
Kettering Motorsports
Unread 22-02-2010, 12:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Burnt Fuses
I'm going to take a wild guess and say this is the spike powering the compressor.
It is a known issue that the start-up amperage of the compressor far exceeds what a normal fuse can handle. You need to use a snap-action fuse that automatically resets - they will handle the overcurrent for long enough (usually) to get past the compressor start up until the compressor drops to the steady-state draw of lower amperage.
Unread 22-02-2010, 13:38
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Burnt Fuses
I'll jump on the "change the fuse to a breaker on the spike that controls the compressor" bandwagon. The compressor will draw more than 20 amps when it tries to start when the compressor is hot. And if your robot is like ours the compressor runs a lot.
The rules are clear on the breaker in a Spike is only for the compressor. If you are going to put a motor on a spike (not the FP or CIM motors) you must use a fuse. Make sure you check the size of the fuse.
Not to push Al off his "use big wire" soapbox, but use big wire. Use #10 wire when possible. Get all the electrons you can to each device. Smaller wires mean voltage drop, lower voltages with the same load means higher currents. Higher currents means burnt fuses. Use big wire!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 22-02-2010, 13:40
Re: Burnt Fuses
That was the rule in previous years, but not this year.
Unread 22-02-2010, 13:50
Re: Burnt Fuses
Sorry, Joe's right, <R60> F The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
Unread 22-02-2010, 22:32
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Re: Burnt Fuses
here's my question. since the breakers for the PD board don't actually fit the slot on the spike, should we use a standard automotive breaker of the same type which actually fits the spike without falling out?
Unread 22-02-2010, 22:39
Re: Burnt Fuses
We have not had any trouble replacing the fuse in the spike with a 20 amp circuit breaker from the kit. Could you further describe the problem you're having?
Unread 22-02-2010, 22:41
apalrd's Avatar
More Torque!
VRC #3333
Re: Burnt Fuses
The breakers on the PD board DO fit in the Spikes. You should be using the 20's, they fit just fine. Both the breaker and fuse are Automotive ATO fuses/breakers, which is what the Spike wants. You must use Snap Action breakers, see <R60>
Unread 22-02-2010, 22:42
AKA: Chris Sherwood
Re: Burnt Fuses
we've put the 20A breaker from the kit into the spike. however, it doesn't seem to seat properly in the spike, so it comes loose and falls out. so we're trying to figure out if it can be replaced with a 20A snap-action breaker from a local automotive store, which should be more certain to fit that slot.
Unread 22-02-2010, 23:04
Re: Burnt Fuses
OK,
The compressor from the KOP has a 25 amp start and 10-12 amp run current rating. The fuse in the Spike is guaranteed to blow. (OK I guarantee it will blow) Maybe not the first or second time but it will blow when you need it the most.
The breaker will only insert one way into the Spike so turn it around if it looks like it can't full insert. It is also possible to insert the breaker (or fuse) at an angle and miss the terminals altogether.
Please remember that off board compressors are required to have a Spike powering the compressor under Crio control. The compressor can be off board but the Spike and pressure switch must be on board.
Unread 22-02-2010, 23:51
AKA: Chris Sherwood
Re: Burnt Fuses
alright, so I guess I'll check that it's in right first thing tomorrow when I get into the shop. I haven't actually worked with the part in the last couple days, so I'm not entirely sure what's going on with it exactly, I'm just asking about what I've been hearing since I'm the "chief delphi guy"
Unread 22-02-2010, 23:52
Re: Burnt Fuses
Everyone should be the Chief Delphi Guy!
Fuses MNov Pneumatics 2 31-01-2008 11:16
has anyone burnt out a joystick?? Leo 1529 Control System 20 30-01-2006 23:25
has anyone burnt out a joystick?? Leo 1529 Technical Discussion 16 24-01-2006 09:57
Who's burnt out already? Anton Abaya General Forum 16 31-01-2002 11:00
Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? Anton Abaya Chit-Chat 4 12-01-2002 14:09
