Go to Post I'm pretty sure most teams would be OK with being somewhere between Division by Zero and Cheesy Poofs! ;) - Dennis Jenks [more]
Unread 23-02-2010, 00:24
Damaku250's Avatar
Damaku250 Damaku250 is offline
Electromechaneumatics guy
AKA: Craig Hoo
FRC #3161 (H.T. Tronic Titans)
Team Role: Electrical
Damaku250 is an unknown quantity at this point
Re: RSL stays on no matter the state of the 'bot
OK, I am going to take another shot here. Are you using the cable that came in the KOP or are you using another cable that just happened to have the same connectors on both ends? The cable supplied is a one for one wiring. Not all cables are made like that and not all have all the pins wired. If this is the cable that came in the KOP then make sure you are fully inserted at both ends. These can look inserted when they are not fully pushed in. Happened in the finals last year at Boilermaker.
My mistake, what we are using is described in This checklist as "2-wire jumper cable 24” PN:03203" at the top of page 12. The wire has had the connector removed from one end, then soldered to small lengths of 18 AWG wire. There is another piece of 18 AWG wire bridging from La to Lb. The light itself appears to work, and the connection appears fine, as it doesn't cut out when the robot is turned on. I will however, double-check tomorrow if the connector is loose. The LED on the sidecar however, does not seem to respond in the proper manner. I will see if I can post a video of it tomorrow or something.
Thanks once again for the help.
-Rookie All Star Award [WAT Regional 2010]
Electrical/Control systems, Mechanical and Pneumatics teams, Human player
Problems with the RSL nofar#1943 FRC Control System 13 13-02-2009 22:09
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
robot program state lite still stays yellow mgs Programming 2 28-01-2005 19:44
'Program State' LED stays blinking yellow after download clynch Control System 5 18-02-2004 19:34
