Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 22-02-2010, 18:23
helenajoy helenajoy is offline
FRC #2437
helenajoy is an unknown quantity at this point
Smile Camera Image on Driver Station/Dashboard
So, our build team decided to mount the camera upside-down. And are leaving it up the programmers to fix this problem. Our driver station is (obviously) returning to us an upside-down camera image. Is there any way to flip/invert the camera image in our code?
Thanks!
Unread 22-02-2010, 19:32
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Camera Image on Driver Station/Dashboard
In Java, C++ should be very similar:
AxisCamera camera = AxisCamera.getInstance();
camera.writeRotation(AxisCamera.RotationT.k180); //or k0.
Eric Haskins KC9JVH
Unread 22-02-2010, 21:49
FRC #2437
Smile Re: Camera Image on Driver Station/Dashboard
Hm, would you by any chance know how to code that in LabView? That is what we are working in.
Unread 22-02-2010, 22:05
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
for some reason changing camera settings in the code never seems to work right. my suggestion is to connect the camera to a computer with a crossover cable, go into a web browser, type in its IP address (ours is 192.168.0.90, i believe yours is supposed to be the same) password should be root and then admin (if this is your programming laptop, make sure to change your ip address so that it starts with 192.168.0.x instead of 10.x.x.x) through the web browser you can access the video settings and flip the image 180 degrees
Unread 23-02-2010, 07:53
If you open Begin.vi, it already sets about six camera parameters. I don't actually see a Set Property VI for setting the camera rotation, though. It would be pretty easy to build.
Do you want this for processing on the robot, or for display on the dashboard. I'd suggest leaving it alone on the robot and simply flipping the resulting X,Y. Then rotate it on the dashboard. This will consume less cRIO CPU.
Greg McKaskle
Unread 24-02-2010, 03:12
FRC #2437
We woulkd like to have it for the dashboard.
Where can I chane the x and y, and how do I flip this image?
Unread 24-02-2010, 08:18
To rotate or modify it for the dashboard, use the IMAQ functions in Vision>>Vision Utilities>>Image Manipulation, and either the IMAQ Symmetry to mirror and flip, or the IMAQ Rotate to spin.
Greg McKaskle
Unread 24-02-2010, 09:45
KyleWishnok's Avatar
KyleWishnok KyleWishnok is offline
FRC #2544 (HCRC)
Team Role: Driver
KyleWishnok will become famous soon enough
if you loosen the screw on the post of the camera you can just put it right side up with the mount on the top opposed to reprograming it
Unread 15-04-2010, 08:05
FRC #2437
I found those VIs. Where in my code would it be best to place it?
Unread 15-04-2010, 10:21
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You want to place it in your Dashboard, after the "get image on PC" vi.
-- Marshal Horn
Dashboard-Driver Station Help Please sircedric4 C/C++ 18 21-01-2010 22:50
How to run dashboard project on driver station baronep Programming 1 18-01-2010 14:58
Driver Station Dashboard Problems CVassos Programming 9 16-01-2010 23:27
Driver Station to Dashboard Laptop connection slavik262 FRC Control System 4 12-01-2010 00:37
