Go to Post Health. Family. School. FIRST. Any other order is a mistake. - pfreivald [more]
Unread 22-02-2010, 19:17
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
pic: Team 293's Robot
Unread 22-02-2010, 19:18
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: pic: Team 293's Robot
We have a long history of using 80-20 and man that stuff is heavy!
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 22-02-2010, 23:04
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
i know... we use it for prototyping because it is easy to adjust the length of things... i was wondering how much that whole chassis weighs
Unread 23-02-2010, 11:28
Cyclotron Cyclotron is offline
Vice Chair, Mid-Atlantic Robotics
FRC #0293 (Team SPIKE)
Cyclotron is a jewel in the roughCyclotron is a jewel in the roughCyclotron is a jewel in the roughCyclotron is a jewel in the rough
We're puzzled when people say that 8020 is "heavy". Heavy compared to what?
The most common profile, 1010, weighs exactly as much per foot as 1 x 1 x 1/8 wall aluminum square tube or 1 x 1 x 1/4 angle. 8020 outperforms these materials in every way. The key to using 8020 is knowing how to join it without using joining plates, brackets or excess fasteners. This robot has only two joining plates, selected for convenience in servicing the drive train.
The chassis pictured weighs in at 29 pounds; the entire robot, fully loaded, is 113. Weight was never a problem this season.
Unread 23-02-2010, 11:31
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
It looks like you're running a bolt through the outside plates and they are tapped into the piece they are connected to? Is this how you're eliminating the need for angle attachments?
How does this method hold up at competition? Do you put locktite or anything on the bolts? Do you have a problem with them staying tight?
Looks great. Good work.
Collin Fultz
Unread 23-02-2010, 11:36
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Compared to .075 wall 1 inch tube it's rather heavy. But for me it has more to do with the aesthetic look of an 80-20 robot and the fact that doing things like non-45 degree miters seems to always need mending plates. Just my two cents. How do you join it without plates? Do you use those pieces that 80-20 makes that you counter sink into the ends? Or something else?
Unread 23-02-2010, 15:21
We counterbore clearance holes for 1/4-20 socket head cap screws (17/64 body, 25/64 head) and screw them into the tapped ends of the extrusion. McMaster sells a step drill bit to do this in one operation (drill press only!) Where 2 or 3 bolts would conflict at a corner, we use 8020 "end fasteners' which require only a #7 clearance hole for the hex key to tighten. Occasionally we use 8020 "anchor fasteners" which require a 9/16 counterbore in one extrusion.
We have done 45 degree and other angled connections. These require a careful drilling setup because of the profile shape.
These connections remain tight without locktite, but we always check everything just in case.
All of the fabrication steps for an 8020 frame can be learned by new team members very quickly, and the results are precise and as strong as they need to be. An 8020 frame is easier to put together than the Kitbot, and it is stronger, stiffer, and straighter.
Unread 23-02-2010, 15:30
Chris is me's Avatar
AKA: Pinecone
While given the choice between the two I'd probably rather use 80/20 for prototyping, the Kit frame, unmodified, is stronger and stiffer than an 80/20 equivalent part. I've seen 80/20 frames bend and warp (and even more pictures of said destruction), but never a kit frame.
80/20 weight stacks up fast, mostly because of all the fasteners you need, and generally people use more of it to accomplish the same things. I'm looking at how adding a few more feet of it added 25 pounds to the robot the other night :/
Unread 23-02-2010, 15:37
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Looks good. I can't wait to see it in action.
(My 272nd post, Go CyberCrusaders. )
Cass
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 23-02-2010, 15:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
There are benefits to square tube and to 8020.
Weight wise, 8020 and 1/8" al are about the same.
8020 is about 2x 1/16" wall, which can be used in many places.
I really like your attachment approach, which provides a big weight savings and space improvement without the corners and extra bolts and t-nuts commonly used.
Very nice, and way to take advantage of capabilities you have and materials you have and come up with a great finished product.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 469's Robot for 2006 pic 1 Don Wright Robot Showcase 11 24-02-2006 16:35
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
