Re: Main Battery Voltage
It is NOT included on the Dashboard but it is on the Driver Station.
Only the first seven (7) analog input are displayed on the Dashboard. You do not have to display on the Dashboard, it on the Driver Station. If it is not on your Driver Station do you see Volts --.-- Under your Team #xxxx |
Thanks everybody I found the problem. we had disconected AI moduel 1 and were using moduel 2 i found the driver station spot where it is displayed. Thanks!
| Battery voltage | Yuan Xue Lim | Electrical | 7 | 04-02-2009 23:10 |
| Main Battery Cables | maclaren | Electrical | 14 | 26-07-2006 12:37 |
| battery voltage compensation | Rickertsen2 | Programming | 5 | 17-10-2005 22:12 |
| Battery voltage | Josh Siegel | Programming | 5 | 22-12-2003 10:15 |
| Battery Voltage | Neal Probert | Programming | 3 | 09-01-2003 10:18 |
