Go to Post Doesn't matter what you use if you can't drive it. - efoote868 [more]
Unread 16-02-2010, 17:24
Team_136 Team_136 is offline
FRC #0136
Team_136 is an unknown quantity at this point
no camera image in the dashboard
We made a new accound, downloaded Axis media control, and still in the dashboard camera image there is no picture. Does anyone know the solution to this problem.
Unread 18-02-2010, 14:56
Re: no camera image in the dashboard
Axis Media Control is not used with the Dashboard display.
This new account, is it on the Classmate or another PC?
If it's on the Classmate then you should run the Driver Station there as well, just to keep things together.
If you're running the Dashboard on a separate PC, then the Driver Station needs to specify the IP address of that other machine (on the Setup tab).
Have you installed all the latest Updates released this past Friday?
Unread 23-02-2010, 15:07
FRC #0136
The account im talking about is the FRC/FRC for the camera. We're running the dashboard on the driver station and we also did the updates that were posted the past friday. In the camera image box it says "timeout in camera communication"
Unread 23-02-2010, 18:49
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
you need to run the Axis Camera Setup Wizard to get the camera properly working. You also need to call (assuming C++ or Java) AxisCamera::GetInstance() at least once to initalize the camera feed. I believe Camera Open.vi in LabVIEW does the equivalent. Camera will also only work with the default camera viewer control in the dashboard (if you are editing it)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
How to get the camera to show images on the dashboard? whcirobotics NI LabVIEW 38 20-02-2010 11:55
Lost the camera part of the dashboard... 1168Programmer FRC Control System 5 15-02-2010 10:30
Displaying Camera Image in C# Dashboard PranavSathy C/C++ 12 08-02-2010 17:06
Reinstall of dashboard doesn't fix camera image streaming ellisk Programming 2 20-01-2010 08:04
Can we use the camera image on Dashboard this year? Jon236 Programming 1 11-01-2010 12:52
