Go to Post Winning a match is not something a robot does, winning is a team effort that requires the cooperation of dozens of individuals. - Andrew Schreiber [more]
Unread 23-02-2010, 18:44
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
signal light
does anyone have a diagram to show how to wire the signal light? We need help.
Unread 23-02-2010, 19:24
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: signal light
It's in the manual. Here's a link:
http://www.usfirst.org/uploadedFiles...t_data_enc.pdf
Look at area A/B 4 on the diagram and you will find the signal light. It gets connected to the Digital Sidecar RSL terminals. Make sure you have the polarity correct. It also appears the two positive terminals on the signal light connect together to a two wire feed that runs to the digital sidecar.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 23-02-2010, 20:05
FRC #3179
Re: signal light
I'm sorry I should have been more specific. What wire should we be using? Should it be the red, white and black wire? Should it come on with the battery power or only through the programming?
Unread 23-02-2010, 20:17
Hodge1
I believe there is a 2 wire cable in the KOP for this purpose, about 24 inches long. Check the KOP inventory and pictures. It is probably already in the software, as it indicates problems to the field personnel, but I am not certain.
It should come on when the robot is powered up. They usually blink, and at various rates from robot to robot (in the past)
Sweat the details
Unread 23-02-2010, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: signal light
We used 20 Gauge wire, one end connects directly to the connector on the back of the light, the other end has a two-pin "PWM-Type" connector on it tjat goes to the RSL connector on the digital sidecar. It does not use the 3-pin PWM (red/black/white) connector, but I suppose you could.
That 2 pin wire (gray outside, little green tag on it) is really for the solenoid valves, not the signal light. Can't say if it's the best choice.
Unread 23-02-2010, 22:27
Re: signal light
ahudson,
Don't worry about the light today. When you get to your first event there will be plenty of help. Just be sure to bring everything from your KOP to the competition. Ask the teams next to you in the pit or check in with your Lead Robot Inspector for help and assistance.
Unread 24-02-2010, 12:44
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: signal light
The easiest way we've found is to use the 2-wire jumper cable from the KoP (the first item on page 12 here). One end plugs into the 2-pin connector on the digital side car (right next to the power connection). The other is stripped and hooked up to the robot signal light. Gnd (or -) goes into the middle position, positive to both of the outer positions. Usually this means you have a small length of wire that goes from one to the other, with the lead to the side car going in one.
The light comes on once the cRio has booted up. When you first turn on the robot, it'll stay dark for about 10 seconds or so. By the time the driver station tells you everything is ok, the light should be flashing.
Unread 24-02-2010, 15:01
FRC #3179
Re: signal light
Thanks for all your input. It was something we kept putting off until the end and low and behold we never did get it to work. We just put it in with the robot and it is on our long list of things to get done at Regional when we get to unbag our robot.
Robot Signal Light smcmahon Electrical 20 08-03-2009 18:11
Robot Signal Light Magnechu Electrical 4 14-02-2009 15:17
FRC Signal Light railerobotics Programming 1 07-02-2009 17:01
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
