Go to Post Part of FRC is to introduce you to how engineering is in real life: you can't use a redo card if you're landing something on the moon. - The other Gabe [more]
Unread 23-02-2010, 20:29
Test, Edit, Build, Deploy, Test
Does LabVIEW have a "MAKE" tool to streamline the "build" portion of the cycle?
Unread 23-02-2010, 20:32
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Re: Test, Edit, Build, Deploy, Test
I know it is possible to hit RUN while corded to the cRIO, but it will not save the code, and may overwrite what is currently saved on there. but, no, I don't believe you can improve a computer's performance by swearing at it.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
I can't build or deploy! Error 6? grosh NI LabVIEW 8 28-02-2009 10:54
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
LabVIEW Woes: Build/Deploy time too long?! leftylink NI LabVIEW 7 27-01-2009 21:52
test coreyk Chit-Chat 0 17-01-2004 11:37
Test- archiver 1999 0 23-06-2002 23:16
