Go to Post What seems logical to you will seem strange to someone else. Never assume that someone else will do the logical thing. - Wetzel [more]
Unread 23-02-2010, 20:30
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Re: PROGRAMMING HELP PLEASE !
common mistake: is the cable plugged into #2 on the cRIO? it should be #1. have you downloaded the new 2.1 labview and 1.1 ds updates? reformated cRIO(v20), reloaded code, rebooted?
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 23-02-2010, 20:32
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Yes we gave plugged it into port #1 and yes we have updated to 2.1 update, BUT 1.1 does not update. If you could please be kind enough to guide us through how to update the DS, if thats the reason the C-RIo isnt giving any packets to the classmate.
Unread 23-02-2010, 20:35
kws4000's Avatar
AKA: Krazy Karl
first, do you have 1.1 DS? once you do, just click autorun.exe. Long time to install it's componenets.
Mentoring:
Unread 23-02-2010, 20:38
FRC #1514 (Vikings)
IT DOES NOT TAKE A LONG TIME TO INSTALL. IT JUST COMPLETES FAST
DS IS NOT UPDATED
Unread 23-02-2010, 20:41
kws4000's Avatar
AKA: Krazy Karl
does the dashboard have a gyro compass on it? if yess, then it is updated.
Mentoring:
Unread 23-02-2010, 20:46
FRC #1514 (Vikings)
OO i already had the ds updated b4, yes it has the compass, but when i entered the driver station:
I get this error " There is an ip address conflict with another system on the network"
WE have not changed the ip but it just happened i dont know why please help much appreciated
Unread 23-02-2010, 20:51
kws4000's Avatar
AKA: Krazy Karl
there should only be the classmate, router, bridge, cRIO, and camera(optional). wild card: any other wireless network in area that for some freak reason has the same IP addresses?
Mentoring:
Unread 23-02-2010, 20:55
FRC #1514 (Vikings)
no we have only the C-Rio with the modules in the correct spot, the classmate which is not broken from all the stress we put on it, the Bridge is connected, and the camera is connected also atm. I do not know any other devices with the same ip address . But for some freaking reason it was working before and suddenly something went horrifically wrong internally, which i got to know about as i came back from eating. So I do not know what happened.
Please if you have any suggestions as to get it to communicate please help, time is golden. only 30 minutes help much appreaciated
Unread 23-02-2010, 21:18
FRC #1514 (Vikings)
tnx for all the help, our time is up. We packed it up. unfortuanetetly did not finish
Unread 23-02-2010, 22:57
Originally Posted by whcirobotics View Post
yes i have:Classmate :
IP: 10.15.14.10
SUBNET 255.0.0.0
GATEWAY: 10.15.14.4
You should never have to set the Classmate's IP address. The Driver Station application sets it for you when you configure it with your team number. But if you've indeed managed to set it to 10.15.14.10, you need to fix it immediately -- it's supposed to be 10.15.14.5 instead.
(The router is probably configured to give out dynamic addresses starting at 10.15.14.10, and that would be why you got an IP address conflict from some other system that connected to the router.)
Urgent Programming C++ help please! Tds123 Programming 5 25-01-2010 15:21
Programming help please?? programmr Programming 1 05-02-2009 11:40
MPLAB PROGRAMMING PLEASE HELP!!! cstringer Programming 6 20-01-2008 13:49
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
Please Help: Programming the Robovation Kit wmurphy Robotics Education and Curriculum 14 08-12-2004 12:57
