#16
Re: PROGRAMMING HELP PLEASE !
common mistake: is the cable plugged into #2 on the cRIO? it should be #1. have you downloaded the new 2.1 labview and 1.1 ds updates? reformated cRIO(v20), reloaded code, rebooted?
#17
Yes we gave plugged it into port #1 and yes we have updated to 2.1 update, BUT 1.1 does not update. If you could please be kind enough to guide us through how to update the DS, if thats the reason the C-RIo isnt giving any packets to the classmate.
#18
first, do you have 1.1 DS? once you do, just click autorun.exe. Long time to install it's componenets.
#19
IT DOES NOT TAKE A LONG TIME TO INSTALL. IT JUST COMPLETES FAST
DS IS NOT UPDATED |
#20
does the dashboard have a gyro compass on it? if yess, then it is updated.
#21
OO i already had the ds updated b4, yes it has the compass, but when i entered the driver station:
I get this error " There is an ip address conflict with another system on the network" WE have not changed the ip but it just happened i dont know why please help much appreciated |
#22
there should only be the classmate, router, bridge, cRIO, and camera(optional). wild card: any other wireless network in area that for some freak reason has the same IP addresses?
#23
Please if you have any suggestions as to get it to communicate please help, time is golden. only 30 minutes help much appreaciated Last edited by whcirobotics : 23-02-2010 at 20:57. |
#24
tnx for all the help, our time is up. We packed it up.
unfortuanetetly did not finish ![]() |
#25
(The router is probably configured to give out dynamic addresses starting at 10.15.14.10, and that would be why you got an IP address conflict from some other system that connected to the router.) |
| Urgent Programming C++ help please! | Tds123 | Programming | 5 | 25-01-2010 15:21 |
| Programming help please?? | programmr | Programming | 1 | 05-02-2009 11:40 |
| MPLAB PROGRAMMING PLEASE HELP!!! | cstringer | Programming | 6 | 20-01-2008 13:49 |
| PLEASE HELP!! Need help programming arm?? | amirjpl | Programming | 12 | 15-03-2007 15:11 |
| Please Help: Programming the Robovation Kit | wmurphy | Robotics Education and Curriculum | 14 | 08-12-2004 12:57 |
