Go to Post Mmmmmmmm. Donuts! - Sean Schuff [more]
Unread 18-02-2010, 23:40
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
encoder works, and then it doesn't.
I was testing out the encoder a few days ago using the encoder vi example provided by ni, and it worked perfectly. The next day, i ran the same exact code, no changes. And it would not work. The electrical person checked the electrical, and the program wasn't changed at all. Any ideas?
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 19-02-2010, 06:11
Noamr Noamr is offline
FRC #1574 (Miscar)
Noamr is an unknown quantity at this point
Re: encoder works, and then it doesn't.
Check the pink devref input that goes into the get encoder vi
Unread 19-02-2010, 09:40
Encoders are fairly fragile. Have you checked it with an oscilloscope?
Unread 19-02-2010, 09:56
jmanela's Avatar
AKA: Joshua Manela
thanks i'll see if we can try both.
Unread 23-02-2010, 20:49
Lucario231's Avatar
Lucario231 Lucario231 is offline
FRC #0033 (Killer Bees)
Lucario231 is an unknown quantity at this point
WELLl i am having the same problem with the encoders not working one day that not working.
Electrical checked them and they are working
The code is not sending errors and the defref is fine
I have 5 NEW encoder and none of them are working.
The encoders do work via voltmeter
Unread 23-02-2010, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
Again, try the encoder VI with no changes and all by itself. If it works, it's your code.
Unread 23-02-2010, 23:14
FRC #1574 (Miscar)
Maybe the encoder example will help- it will remove any doubt of code issues.
You should also check that it's being initialized right:
We had a problem when we accidentally deleted the wiring between the begin VI to the sequence that calls the vision VI and the periodic VI. So the encoders devref did not show an error, but on the other hand it also did not show the right channels or mode (it's supposed to be on 4X).
Unread 27-02-2010, 14:21
jmanela's Avatar
AKA: Joshua Manela
thanks for all the help. The encoder's didn't work because of a bad digital sidecar, but now something wierder is happening. When I run the raw encoder get program, i get different values (distance) it each time i run the program.
vex encoder works with innovation first? cau.denny General Forum 1 28-02-2009 08:17
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
pic: Mike Williams, then and now Rich Kressly Extra Discussion 7 07-04-2006 21:45
And then it hit me.... Joe Johnson General Forum 12 07-02-2002 22:29
And then there were none... Joe Johnson General Forum 2 21-10-2001 23:31
