Go to Post I've been busier than a hog farmer at feedin' time. - Andy Baker [more]
Unread 23-02-2010, 17:44
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Robot resets on its own
We turn the code on and wait for everything to wait and connect properly and loads the code. Right after we enable and move the joysticks, the robot resets on its own. We checked all the wires and everything is correct.
Does anyone know why this is happening? Is it code or wiring?
Thanks alot
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 23-02-2010, 20:20
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Robot resets on its own
What's your battery voltage at?
When you run your motors, your battery voltage actually drops. Normally this isn't a problem, but if the battery is already very low, it can drop so much that the 24V supply on the power distribution board cuts out.
Unread 23-02-2010, 21:55
DonRotolo's Avatar
Back to humble
FRC #0832
Sounds like a wiring problem to me, put a voltmeter on the 24V input to the cRio and watch it while you duplicate the problem. Betcha it drops to less than 10 volts.
Unread 23-02-2010, 22:30
I'll bet a bag of donuts that one of your motors is either frozen (stalled) or the wiring is shorted. Check again with a bright light. Try pulling all the breakers to your motors and turn the power on. Move the joysticks. If the CRio does not reboot, insert one of the breakers and move again. This will show you where the problem lies.
Unread 23-02-2010, 23:01
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Thanks alot
My team faced a very similar problem a few days ago. When ever we moved the robot reset. We loaded the simplest code we could find (simple template example mode) and we found out it was not our code. You should try that.
If the problem happens only when you move, I would check and test your speed controllers. Ours reset because one of our jaguars was broken.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 24-02-2010, 04:34
code789 code789 is offline
AKA: Martin
FRC #2990 (Hotwire)
code789 is an unknown quantity at this point
you should change your battery the cRIO will shut down when the voltage goes below 5V
Unread 24-02-2010, 09:47
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
My team also faced this problem this year, and we found that the main battery line was touching our chassis! This caused a short out when we traversed the bump.
After inspecting the battery lines, we found a hole the size of a pencil tip that was caused from friction poking a hole in the wire!
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 24-02-2010, 10:18
Mentor, LRI, MN RPC
Come on Railer... what was the problem? I'm just waiting for you to tell us it was a low battery so i can win that bag of donuts from Al. mmmmmmm, donuts!
Unread 24-02-2010, 11:23
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
As if you havent already heard this enough, it is most likely an electrical problem. Either you are running a low voltage below 10volts, or there is a short between your batt. and ur electrical board. But is the entire cRio reseting? A locked up motor will blow the breaker, and there will be a 3 second delay for the breaker to reset, but this is only for the breakers controlling the motor, it shouldnt affect anything else on the robot.
But i will say again this reminds me of a low voltage issue; when you begin to drive the motors pull enough current to bring the voltage down low enough to cause the robot to briefly shut off.
Bumping resets bot Tottanka Programming 6 11-02-2008 16:47
RC resets itself when robot tries to move cheesinglee Electrical 28 04-07-2003 21:59
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Build Your Own Robot Kit Rich Wong Robotics Education and Curriculum 2 30-12-2002 20:50
thinking of building my own robot... archiver 2001 8 23-06-2002 23:27
