Go to Post At this point in build season, I'm thinking that whatever type we can get built and working is the best type, by far! - MrForbes [more]
Unread 23-02-2010, 22:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Team 95 finished
Video of a mock competition/practice time. We have a really good match-up with Team 1922 (you guys were awesome) they scored a few goals on us, but we kept them at bay most of the time. It was pretty awesome to see to Mecanum drive robots that were really well balanced against eachother go at it. Talk about dancing robots... We had a couple issues with the practice field falling apart a little, but it wasn't too bad.
Video: http://www.youtube.com/watch?v=lredBHWxJxM
Our blocker fully deployed (and painted) we can also drop it to 45deg to deflect balls dropping down from the ball return.
Most of the guts here... we mounted the battery and compressor underneath.
It sports 4-Cim+mecanum drive, can go over the bump (and catch air!), strafe on the bump, go through the tunnel, auto-kick and score from the 3rd zone, block virtually any shot, and deflect balls from the ball return. Weighs in at 113lbs. The only thing we can't do is hang, but since we'll be playing goalie, and hanging doesn't get you many points, we should be okay. We're running pneumatics at two different pressures to conserve air. The blocker is damped pretty well so blocked shots don't bounce too far, great for blocking and then kicking the ball away.
It's the best 'bot you can buy from McMaster and assemble in a High School, 6 parts were machined, 2 were welded, everything else was done with hand tools.
What do you think!?
Edit: updated with video!
Unread 23-02-2010, 22:15
RMR: TeamPlasma's Avatar
RMR: TeamPlasma RMR: TeamPlasma is offline
Programer
AKA: Michael Przeslica
FRC #2403 (Red Mountain RObotics, Team Plasma)
RMR: TeamPlasma is an unknown quantity at this point
Re: Team 95 finished
What do I think? I think "om nom nom" XD. That blocker is priceless!
Your electronics/pneumatics board? One of the cleanest I have ever seen!
I wish you the best of luck!
Unread 23-02-2010, 22:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That is EXACTLY what our artist put in the sketch he made of it
Unread 23-02-2010, 22:42
Chris/Fish Chris/Fish is offline
FRC #0449 (Blair Robot Project)
Chris/Fish is an unknown quantity at this point
Nice job! It was great to work with you guys this year
One question: what did you end up using to keep the balls out from under the robot?
make that two: are the pressure gauges visible when the blocker is all the way down?
Unread 23-02-2010, 22:48
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
What did you use to "damp" the blocker?
It looks excellent! Great job.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 23-02-2010, 22:53
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Two quick questions.
Do you have a primary regulator mounted somewhere else? And does that panel tilt slightly out of the frame perimeter when up like that?
BTW Love the graphics.
Unread 23-02-2010, 23:02
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Thanks for scrimmaging with us this weekend at St. Paul's. Your blocker looks much better painted and bot looks great and look forward to competing with you at Granite State Regional.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 23-02-2010, 23:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
On the two narrow sides we simply have an aluminum bar, on the rear we're using some huge zip-ties, and on the front with the kicker it will be a zip tie and bungee chord.
They are not, though the blocker is not not powered in the down position, so one can lift it up at any time.
Flow control valves on the four pistons that deploy the blocker, it's not perfectly "dead" though.
No we do not, but the pneumatic vent is accessible from the outside of the robot. And no, the blocker hinge is recessed inside of the frame perimeter so it comes up flush with the frame when it's deployed.
I see <R76> wants the pressure gauges to be "easily visible" which they are if the blocker is lifted by hand, if the inspectors don't like it, which they might not, I guess we'll have to relocate the gauges.
EDIT: Having gotten punched in the face by the blocker due to an overly zealous freshman I think that lifting the blocker out of the way is safer than having a view port through it because one's face will not be in the way of the blocker if it deploys
Unread 23-02-2010, 23:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The question was about a primary regulator. The main regulator going from 120PSI to 60 PSI must be a Norgen regulator, this is the all black regulator on the top of page 27 of the KOP checklist.
The 2 pictured regulators are both Monier (sp?) secondary regulators.
Unread 23-02-2010, 23:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Ah, good catch. I guess we'll swap that out first thing when we go to competition. Thanks!
Unread 24-02-2010, 16:21
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
OP has been updated with a video!
Team 2073 Finished on time!! billbo911 Robot Showcase 0 17-02-2009 13:34
Team 2080 Finished Robot Torboticsmember Robot Showcase 0 29-02-2008 14:28
Team 1279's finished robot. KingBK General Forum 3 22-02-2007 18:24
Team 701's finished animation! Salik Syed 3D Animation and Competition 6 14-02-2006 22:09
