Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 22-02-2010, 16:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
cRIO Image? Need help soon!!
Hi-
Ever since we have updated to v20 of the cRIO, our Jaguars have been hating us.
We are using CAN, but the Jaguars are intermittently cutting out, at a seemingly random order. We are using the exact same code, and sometimes it works, sometimes it doesn't.
We have tried changing out cRIOs, and created multiple workspaces (C++) and to our frustration, nothing seems to work.
Edit:
All of our Jags are blinking a very fast yellow, something that is not listed in the Jaguar PDF chart...
Unread 22-02-2010, 19:29
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: cRIO Image? Need help soon!!
try replacing the cables
Unread 23-02-2010, 04:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Originally Posted by nighterfighter View Post
Hi-
Edit:
Do you get this behavior with v19? What version of the Jag firmware are you using? Are you using the 2CAN or the BlackJag bridge?
Unread 23-02-2010, 23:55
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
We had this exact same problem. The root of it is there is something with your robot that is causing WPILib errors at an extremely high rate, which slows down the code enough to cause the jags to miss their internal watchdog and freeze up (as far as I could tell). Our exact problem was our camera mount was constantly pressing the camera reset button, causing the cRIO's camera init to fail and fail again until the system just gave up.
Also, if any jags are messed up (reset IDs, no breakers, broken cable, etc) and you are sending commands to them, if enough are down then I've found the intermittent trouble and sluggish controls (another symptom btw) shows up too.
To the folks at WPI if you are reading this: Please cut down on your errors. At the very least, put a timer on them to limit the rate of errors being thrown. They seriously are a problem for anything that can cause an error on every single Teleop loop. In the time between cRIO finishing boot and camera finishing boot, we can still sometimes have this problem (NetConsole definitely shows the overflow of errors).
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 24-02-2010, 00:05
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
Yep. Part of the code I wrote had to be commented out because number of errors that were popping up was causing serious lag (NetConsole was displaying errors faster than the eye can see).
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 24-02-2010, 14:32
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
I'm not really sure what "errors" you're talking about.
How is it WPI's fault if your camera mount causes it to continually reset? Isn't that your mistake?
What kind of errors are you seeing in every teleop loop? If it's something wrong with the WPI library, they're probably going to be able to fix it faster if you can provide some more details.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 24-02-2010, 14:47
AKA: Ian Thompson
It's not the errors themselves that I'm complaining about, the problem is how wpilib handles those errors. There is nothing limiting the rate of errors being printed to stdout, so repeating errors slow everything down
cRio doesn't re-image Lilszamora FRC Control System 3 15-02-2009 21:06
Crio image download brainsdmaner FRC Control System 2 15-02-2009 01:06
cRIO Image version? Chris11246 Programming 1 14-02-2009 16:44
Need help with CRIO GillSt.Bernards Electrical 4 14-02-2009 14:42
In need of PWM Cables! SOON! Travis Covington Electrical 2 19-02-2004 20:55
