Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 24-02-2010, 09:49
Rikard023's Avatar
Happy Birthday! Rikard023 Rikard023 is offline
Programmer/Animator/Captain/Ninja
AKA: Rikard
FRC #0522 (The Robowizards)
Rikard023 is an unknown quantity at this point
Send a message via AIM to Rikard023
need Solenoid help
If anyone knows how to write a solenoid program correctly or any where i can get info on it, I would be very Grateful
"Sharp edges are prone to cause bleeding trust me i know" T.T
http://www.robowizards.com
Unread 24-02-2010, 10:06
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: need Solenoid help
Have you looked at the documentation? It should give you a good start.
Unread 24-02-2010, 11:05
Rikard023's Avatar
AKA: Rikard
Yea i looked at it and wrote from it and it didn't work
Unread 24-02-2010, 13:05
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Are you doing pneumatics? If so, there are a number of ways to wire pneumatics. Assuming you hook the pneumatic valve to two Solenoid channels (DO channels). Here is the code to operate it.
Disclaimer: I am new to pneumatics, so this may not be the right way to do it, but it works for us. Another way to do it is to use a relay instead of two solenoid channels but it requires a relay.
#define SOLENOID_EXTEND_CHANNEL  1
#define SOLENOID_RETRACT_CHANNEL 2
private:
    Solenoid *m_solenoidExtend;
    Solenoid *m_solenoidRetract;
// In some constructor
    m_solenoidExtend = new Solenoid(SOLENOID_EXTEND_CHANNEL);
    m_solenoidRetract = new Solenoid(SOLENOID_RETRACT_CHANNEL);
// To extend the pneumatics
    m_solenoidRetract->Set(false);
    m_solenoidExtend->Set(true);
// To retract the pneumatics
    m_solenoidExtend->Set(false);
    m_solenoidRetract->Set(true);
Unread 24-02-2010, 13:13
mikets's Avatar
Software Engineer
Forgot to mention a few more things: make sure your DO module is in the default slot 8 (or you have to specify the slot in the code). Also make sure the soloenoid bumper is powered with appropriate voltage. FIRST provided 24V valves this year, so you need to feed 24V to the bumper (not 12V).
Unread 24-02-2010, 13:35
mikets's Avatar
Software Engineer
BTW, forgot to mention one more thing: you need to create a compressor object too. The compressor power should be hooked to a Spike relay and the pressure switch should be hooked to a digital input channel.
#define PRESSURE_SWITCH_CHANNEL  1
#define RELAY_COMPRESSOR_POWER  1
private:
Compression *m_compressor;
    m_compressor = new Compressor(PRESSURE_SWITCH_CHANNEL, RELAY_COMPRESSOR_POWER);
    m_compressor->Start();
Unread 24-02-2010, 14:20
Rikard023's Avatar
AKA: Rikard
thanks that should be egood enough
Need help with Festo Solenoid and Labview Team2883 General Forum 3 17-02-2010 12:56
Need help with SMC solenoid valves Ed Law Pneumatics 6 04-02-2010 06:43
Solenoid Help aznbadboixx Pneumatics 0 15-02-2008 15:53
Solenoid Help Brigander Programming 2 14-02-2007 17:13
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
