Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 24-02-2010, 15:25
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Invitation for opinions on 3" engagement rule
We are having some post-ship contemplation on the possible interpretations of the 3" engagement rule. I realize this topic has already been discussed thoroughly, but we had a certain interpretation to invite comment on.
If you have a "V" shaped inclusion with the V opening upwards such that the ball can rest in it by more than 3", this is certainly a violation of the engagement rule. If you turn that same "V" shape 45 degrees so that one leg is vertical, you have changed the orientation of the situation, but technically the ball is still engaged by the geometry of the robot by more than 3" (see pic). The rule does not say anything about the orientation of the engagement, or what the orientation is with respect to the floor or gravity.
So, does this mean that a flat top or even a domed or sloped top cannot intersect a vertical feature if the vertical feature is tall enough for the resulting "V" engagement to be more than 3"? There are certainly some finished robot designs out there which would violate if this is the case. This is related to but separate from the issue of whether the vertical "V" shape feature might control or "carry" the ball when the robot is in motion.
Name:	V Shaped Engagement.jpg
Unread 24-02-2010, 15:38
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Invitation for opinions on 3" engagement rule
I think it will be clear that your proposed scenario will not be legal. check out the FRAME PERIMETER rules and think about how you could legally create such a device inside the frame perimeter and yet not allow a ball 3" under the frame perimeter.
The robot footprint is defined by the FRAME PERIMETER and you can't have the ball more than 3" under that. Your FRAME PERIMETER is defined inside the BUMPER ZONE which is above the height of a ball, so you can't do this without violating the FRAME PERIMETER.
Just my thoughts.
Rob
Unread 24-02-2010, 16:23
jspatz1's Avatar
AKA: Jeff
We meant above the bumpers. Sorry, not specified.
Unread 24-02-2010, 16:43
Brown 2010's Avatar
Brown 2010 Brown 2010 is offline
AKA: jason
FRC #2010 (the Lightning Bots)
Team Role: Driver
Brown 2010 is an unknown quantity at this point
i think the rule you are looking for is this:
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside
a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5),
b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE.
does this help?
Unread 24-02-2010, 17:57
jspatz1's Avatar
AKA: Jeff
does this help?
That is the rule in question. The intrepretation as described above is the question.
Unread 24-02-2010, 18:34
Brown 2010's Avatar
AKA: jason
Team Role: Driver
a GDC answer to a question regarding a similar situation:
The prohibition in Rule <R19-B>, as amended in Team Update 2, is against BALL incursion inside any particular MECHANISM on the ROBOT. It is understood that the BALL may enter inside the vertical project of the FRAME PERIMETER of the ROBOT (i.e. be "inside" the ROBOT boundaries). A situation where the BALL traverses "inside" the robot boundaries (e.g. as it falls from the BALL RETURN and bounces off the top of the ROBOT), but does not enter a MECHANISM by more than the permitted 3 inches, would not be PENALIZED
my interpretation of this combined with updates #2 and #9 is that unless the "V" shape is designed to manipulate the ball, then it is legal.
in my opinion, unless you have a complete "cage" around every part of your robot to block the ball, a ball will enter the frame perimeter more than 3".
Unread 25-02-2010, 12:37
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
The way we interpreted this, any part above the bumpers that has the effect of benefically controlling the direction of a ball, whether intended solely for that purpose or not (roll bars on each end of the robot, etc), would form the "boundary" for the 3" dimension. Parts that stick out but are not beneficial to ball control (a thin arm for a lifter, etc.) would not define the 3" boundary. This is just our opinion, for what its worth. The ref's make the call.
We have roll bars and an angled deflector plate on the top. We arranged things to make sure that the deflector plate stayed within 3" "boundary" defined by the roll cage.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Need Opinions On Rule <R02-C> RoboTigers1796 Rules/Strategy 8 07-02-2009 12:14
2008 MARC "Rules of Engagement" Steve Ketron Off-Season Events 8 08-05-2008 23:42
"Your Honest Opinions" Kyle General Forum 29 26-04-2005 15:11
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Rules of Engagement and "Unfair Competition" Richard Neese General Forum 2 24-03-2003 13:03
