We did not have any
Wait() I think it might be the camera's Code:
camera = AxisCamera::GetImage() Has anyone ever have this problem before? |
Re: Watchdog Not Fed!
Are you disabling the watchdog during autonomous and during the constructor? The watchdog could be expiring before the teleop function sets it up properly
I don't understand your code. Did you mean:
camera = AxisCamera::GetInstance(); or HSLImage *image = camera.GetImage();
We had a similar problem. Discovered that the accelerometer was plugged into to the duplicate I2C _OUT_ ports. The accelerator initialization in the robot constructor was simply hanging, so our robot class never made it out of its constructor. So, as soon as the robot was enabled, the watchdog went hungry because our code hadn't started feeding it yet.
I guess the lesson from that is: make sure your code is getting to where you think it is, and check everything. |
| Watchdog not fed | brianelite | C/C++ | 12 | 14-03-2010 14:43 |
| Enabling yields one "Watchdog not fed" flash | Dylan5019 | Programming | 4 | 12-02-2010 23:45 |
| Autonomous Independent Code Issue Watchdog not fed | pilum40 | FRC Control System | 0 | 11-02-2010 12:00 |
| Watchdog Not Fed but, All Systems Are Go. | DHSrobotics | Java | 4 | 24-01-2010 22:01 |
| Watchdog not fed | ahudson | Programming | 1 | 22-01-2010 11:26 |
