Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 24-02-2010, 15:36
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
Toughbox Nano - counts per wheel revolution?
We don't have a spare gearbox so I can't measure this now. What is the turns ratio between the wheel and the encoder? (assuming standard overall gear ratio of 12.75:1).
Or, stated another way, with the kit of parts encoder, how many counts per wheel revolution?
Unread 24-02-2010, 16:19
Re: Toughbox Nano - counts per wheel revolution?
Isn't the encoder on the output shaft?
Unread 24-02-2010, 18:14
From the KOP checklist:
  • The KOP output sprocket is 15-tooth
  • The wheel sprocket is 22-tooth
From the sensor manual:
The encoders provided are 360 Codes per Revolution (CPR). With 4X quadrature decoding, you get 1,440 positions per revolution...
Changing Gears in Toughbox Nano? RyanCahoon Motors 3 28-01-2010 11:03
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
Build Counts Idaman323 General Forum 7 12-03-2006 23:37
Post Counts? Jeff Waegelin CD Forum Support 2 28-02-2003 20:04
What really counts?? archiver 2001 4 23-06-2002 22:42
