Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Unread 24-02-2010, 15:55
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Re: Joystick button to trigger pneumatic kicker?
Make sure you have the right 'getref' for the joystick connection.
Try assigning another button besides #8 in case the joystick button is bad.
One other observation, if you don't hold the button down for a moment you may not see any movement in the cylinders before it switches back to the 'false' case.
Unread 24-02-2010, 16:04
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
We probed the joystick button and it did cyle between true and false when the button was pressed.
How does the code look?
Should we add some delay?
Unread 24-02-2010, 16:16
AKA: Mr. Don
Delay is up to you and how you want the button to work. Code looks okay. For the 'True' case to work you have to hold the button down. As soon as you release the button, the loop becomes 'False'.
Team 1522's pneumatic kicker kornjones Robot Showcase 0 15-02-2010 20:59
pic: Pneumatic Kicker Rev_1 professor1212 Extra Discussion 6 17-01-2010 23:07
Joystick Trigger Programming dnrobotics11 C/C++ 7 09-02-2009 19:27
Programming the joystick trigger... pudgeball C/C++ 4 10-01-2009 10:25
360 Button, trigger, and joy stick? GMAdan Programming 4 16-01-2007 19:07
