Go to Post I've been busier than a hog farmer at feedin' time. - Andy Baker [more]
Unread 24-02-2010, 15:12
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Joystick button to trigger pneumatic kicker?
Help!
Of course the robot wiring was completed at the last minute and the programmers only had about an hour to check there code. The good news is that most of there code worked flawlessly. The bad news is our pneumatic kicker did not operated as planned AND we shipped our robot yesterday so we can't debug the code.
Can someone look at our pneumatics program so we can determine if the error is our program and/or wiring before we get to our regional next week?
Specifics:
The compressor came on but the solenoid did not fire when the button was pressed.
We are using three double acting cylinders w/ three solenoids.
We want the cylinders retracted when the button is not pressed (this is what we think the false case should cause it to do).
We want the cylinders to extend when the button is pressed (this is what we think the true case should cause it to do).
Thanks- Any help would be appreciated.
Name:	pneumatics false.jpg
ID:	8799  Click image for larger version
Unread 24-02-2010, 15:41
bstites82 bstites82 is offline
AKA: Blake Stites
FRC #2164 (multiple)
bstites82 is an unknown quantity at this point
Re: Joystick button to trigger pneumatic kicker?
well you might try wiring a button to the little green questin mark on your case structure, other than that the logic seems sound
Unread 24-02-2010, 15:46
FRC #2147
Your right! I am at home sick today and don't have access to the programming laptop. The code I posted was recreate from memory. Our actual code does have the ?mark connected to button 8.
Unread 24-02-2010, 15:55
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Make sure you have the right 'getref' for the joystick connection.
Try assigning another button besides #8 in case the joystick button is bad.
One other observation, if you don't hold the button down for a moment you may not see any movement in the cylinders before it switches back to the 'false' case.
Unread 24-02-2010, 16:04
FRC #2147
We probed the joystick button and it did cyle between true and false when the button was pressed.
How does the code look?
Should we add some delay?
Unread 24-02-2010, 16:16
AKA: Mr. Don
Delay is up to you and how you want the button to work. Code looks okay. For the 'True' case to work you have to hold the button down. As soon as you release the button, the loop becomes 'False'.
Team 1522's pneumatic kicker kornjones Robot Showcase 0 15-02-2010 20:59
pic: Pneumatic Kicker Rev_1 professor1212 Extra Discussion 6 17-01-2010 23:07
Joystick Trigger Programming dnrobotics11 C/C++ 7 09-02-2009 19:27
Programming the joystick trigger... pudgeball C/C++ 4 10-01-2009 10:25
360 Button, trigger, and joy stick? GMAdan Programming 4 16-01-2007 19:07
