Go to Post FIRST MANTRA: When Lawyer-ism fails, Gracious Professionalism Prevails! - sanddrag [more]
Unread 24-02-2010, 18:11
Re: Connecting Pneumatics to make it achieve 115 psi
So you are using an off board compressor? If after you close the valve, the high side pressure falls, then you have a leak somewhere. It could be on the low pressure side since the regulator will keep supplying 60 psi until the high side falls to 60 psi. Let it sit and watch what happens. You have a leak somewhere. The system components can usually hold pressure for several minutes to an hour or more with no leaks. Use the soapy water technique. Mix some liquid soap into water and wipe on to all the joints. A leak will produce bubbles when you add the soap solution to the joint. This could be a threaded joint or a hose fitting. On rare occasions the vent valve can leak but it is very rare.
programming pneumatics psi thatoneguy23 Programming 6 28-01-2010 09:46
Trackball PSI pumbaa2007 General Forum 2 12-01-2008 19:39
Potential MVRT(115) Design... HFWang Website Design/Showcase 11 17-11-2004 22:14
How to make Pneumatics use less air sanddrag Pneumatics 1 16-02-2004 15:50
Team 115 - El Toro 6 activemx Robot Showcase 3 23-02-2003 15:45
