Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 19-02-2010, 11:04
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
ELEVATED ROBOT
Hello,
Is there any rule regarding how high above the floor the robot must be hanging on the alliance tower?
because our robot is in line at an angle on the alliance tower;
It back is about half meter above the floor and it front is about 15 centimeters above the floor.
My question: Is it enough high to get points?
Unread 19-02-2010, 11:06
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: ELEVATED ROBOT
your robot must be above the plane of the top of the platform, so above 20 inches and you get the bonus
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 19-02-2010, 11:23
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: ELEVATED ROBOT
thank very much,
but what part of the robot must be in that height?
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
Re: ELEVATED ROBOT
I think that it is the entire robot that must be over the plane
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 19-02-2010, 12:31
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: ELEVATED ROBOT
thank you,
Can you show me that rule it need to be 20 inches above the ground? because I can't find it.
Unread 19-02-2010, 12:32
Re: ELEVATED ROBOT
<G04> Scoring - ALLIANCE scores are determined by a combination of the number of BALLS SCORED in the ALLIANCE GOALS during the MATCH and the number or ROBOTS in the following states at the conclusion of the MATCH, where:
a. Each SCORED BALL is worth 1 point, and
b. Each ELEVATED ROBOT is awarded 2 points, or each SUSPENDED ROBOT is awarded 3 points.
ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
SUSPENDED: A ROBOT only in contact with an ELEVATED ROBOT and/or a SUSPENDED ROBOT shall be considered SUSPENDED.
Unread 19-02-2010, 12:35
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: ELEVATED ROBOT
Originally Posted by yarden.saa View Post
thank you,
There you go.
___________________
- Tennyson, Ulysses
Unread 19-02-2010, 12:45
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: ELEVATED ROBOT
thank you,
I checked it with the field drawings and the robot must be above 19-1/4", am I right?
Unread 19-02-2010, 12:49
Re: ELEVATED ROBOT
thank you,
Above the platform is the rule. The platform is listed as 20" above the floor. There may be some tolerance issues of up to about 1/4".
Plan for 21", that should cover all cases.
Unread 19-02-2010, 12:53
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: ELEVATED ROBOT
thank you, our alliance tower is 24 (the man who built it for us made a few mistakes)and it cant elevate more the 15 centimeters in the dront and half a meter in the back, it stuck at the tunnel, so I guess it should work with legal tower.
Unread 19-02-2010, 12:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: ELEVATED ROBOT
15cm is less than 6 inches. If that is the highest the front of your robot gets when trying to elevate it will not be above the platform and will not score points.
As EricH said above, design your robot to lift all parts above 21" or ~53cm to 54cm
Unread 20-02-2010, 00:45
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: ELEVATED ROBOT
I think when my toewr will be legal the robot will lif him self more then the last time becase the height is so different.
Unread 24-02-2010, 20:13
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: ELEVATED ROBOT
If the robot hangs and for some reason cant winch itself up all the way and the back wheels are above the plane of the platform and the front wheels are ON the platform, does this count as an elevated robot (2pts)?
Unread 24-02-2010, 20:28
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: ELEVATED ROBOT
As long as absolutely no part of your ROBOT is below the plane of the PLATFORM you are ELEVATED.
Unread 24-02-2010, 20:32
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: ELEVATED ROBOT
yeah... if anyone watched the suffield shakedown you have to be above the platform... there were a few robots that hung, but the bonus didn't take affect because they weren't above the tower platform
ELEVATED but not hanging? Kevin Sevcik Rules/Strategy 52 01-02-2010 18:19
ELEVATED ROBOT means ELEVATED ROBOT to the Towe or and Platformr yara92 Rules/Strategy 4 26-01-2010 19:42
Elevated bots DNay247 Rules/Strategy 10 13-01-2010 19:53
question:define elevated? cbeavers6790 Rules/Strategy 6 13-01-2010 18:47
