Go to Post I would like to complain about the game as well. Complain, complain. - Monochron [more]
Unread 24-02-2010, 18:32
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Gyro Wiring?
This is our second year and the first time that we have attempted to use a gyro on our bot. I looked at the gyro example given in Lab View and it show a diagram intended to explain how to wire the gyro to the analog breakout. However I find this diagram to be not very detailed. Is there a better description/image out there some where explaing how exactly to wire a gyro to our bot. I dont want to take the risk of wiring it wrong and destroying the equipment. Thanks.
Unread 24-02-2010, 20:55
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Gyro Wiring?
The gyro needs to hook up using a 3 wire "pwm cable". Solder either the pins of the pwm cable or a 3pin female header (don't know where to get them right off hand). The outer edge is negative (black wire), you don't need to hook up both sets just the outer set that says "gyro". The female end goes to the analog I/O default is port#1 if you have it hooked up for use on the default driverstation diaplay.
Unread 24-02-2010, 21:12
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Re: Gyro Wiring?
Originally Posted by Mike AA View Post
The gyro needs to hook up using a 3 wire "pwm cable". Solder either the pins of the pwm cable or a 3pin female header (don't know where to get them right off hand). The outer edge is negative (black wire), you don't need to hook up both sets just the outer set that says "gyro". The female end goes to the digital I/O default is port#1 if you have it hooked up for use on the default driverstation diaplay.
No..the gyro goes to the ANALOG I/O Module on the CRio...make sure you set the sensitivity to .007 V Deg/sec
Unread 03-03-2010, 10:22
FRC #3055
Re: Gyro Wiring?
Where do you set the sensitivity?
Unread 03-03-2010, 10:37
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Re: Gyro Wiring?
You set the sensitivity (usualy called gain) in software. The base gain for the 2010 KOP gyro is .007 volts/degree/second. In labview, one of the terminals on the open-gyro block is gain, and you can just wire a constant of .007 to it.
However, I believe that the latest labview update made the default gain .007 to match this year's gyro, so if someone can confirm that you may not need to worry about any of this.
Unread 03-03-2010, 10:50
Re: Gyro Wiring?
Until next year when your old robot code stops working because you used a default that gets changed periodically...
Wiring Gyro PingPongPerson Electrical 1 11-02-2010 21:27
Gyro wiring? Phoenix Spud Electrical 7 12-01-2009 13:58
Help: wiring ADXRS300EB Gyro Eval Boards de_ Sensors 3 18-03-2008 22:21
2003 Gyro Wiring Harness DukesAZ Electrical 3 03-02-2005 18:20
2003 Gyro Wiring Harness DukesAZ Technical Discussion 3 03-02-2005 18:20
