Go to Post As Grandma used to say, "empirical data is better than no data at all." - dlavery [more]
Unread 24-02-2010, 21:00
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
Re: solenoid and compressor code
so do i just need to set up the begin vi file like you show in the screen shot
and it should work?
I also have the solenoid set up with control on the joystick trigger in teleop and autonomus.
the solenoid and compressor is quite a bit different than your screen shot,
does that matter?
thanks much John
solenoid with compressor vi ElanaC NI LabVIEW 42 29-12-2010 13:38
Solenoid Wiring and Compressor Help BurtGummer Electrical 16 17-02-2010 14:25
How to program solenoid and compressor? Jason F Java 8 08-02-2010 15:15
Question about Solenoid and default code waialua359 Control System 4 21-01-2006 18:21
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
