Go to Post How many of the team's current students were even alive when those awards were earned? :) - Alan Anderson [more]
Unread 25-02-2010, 08:44
WIllowSquID WIllowSquID is offline
FRC #1877
WIllowSquID is an unknown quantity at this point
voltage reading
Currently we aren't getting a voltage reading at the driver station. We don't have a clue on how to do this. Can anyone provide any advice?
Unread 25-02-2010, 09:23
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: voltage reading
I'm assuming you're talking about battery voltage.
On the analog module breakout, there is a 3 pin male header outside of the blue plastic. You must insert a 2-pin 0.1" molex connector (the ones used for the Digital Side Car servo headers work fine) across the outer 2 pins of that header. You will not get battery voltage unless you jump these two pins.
Unread 25-02-2010, 16:04
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
Re: voltage reading
You also must wire 12 volts into the power connector on top of the analog breakout module.
Reading Encoders? Questions4mQ202 C/C++ 13 25-01-2009 20:47
paper: Reading the FTC Battery Voltage PhilBot Extra Discussion 4 16-01-2009 08:46
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
