Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 25-02-2010, 14:43
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
1058's Field Oriented Drive
Here is some video of our field oriented drive system for 2010. Basically no matter which way the robot faces if you push the joystick forward it will go forward.
I know it's been done before but it's beautiful anyways and it uses some neat technology to automatically reset its position when pushed or after going over the bump.
http://www.team1058.com/media/video/...dDrive2010.mov
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 25-02-2010, 16:35
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Re: 1058's Field Oriented Drive
I got to say....that is by far the smartest bot I've seen...
I understood and even think I can replicate the field orientation with the gyro, but...how does the positioning work ?
Again...I'm highly impressed.
Unread 25-02-2010, 16:40
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
you're selling yourself short in this post I think, that is probably the smartest robot I've seen, and it would probably be very easy for a rookie driver to pick up the joysticks and learn quickly how to drive.
Have you tried using a gamepad of some sort instead of joysticks?
beautiful programming though
Unread 25-02-2010, 16:43
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
Very slick code work and explained so well that even I, a programing illiterate, could understand it.
Good work
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 25-02-2010, 16:49
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
That is amazing! just like in the posts above, i cant do crap with programming and yet i could now describe how this works to our programming team
you guys should get a big award for this cause that ROCKS!
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 25-02-2010, 16:55
Very impressive programming. One of the most intuitive robots of the year so far.
Unread 25-02-2010, 17:43
AKA: Mike Jr.
Thanks for the compliments! I'm not going to give away all the secrets without permisson from the 2 guys who programmed it (Brendan the guy in the video being one of them)
We're really happy with how it worked out. We ended up buying a nice 3axis joystick so you can just twist the handle to rotate the robot. We also added some automatic features for balancing on the bump and aiming purposes. Check out this video to see the bot on the bump and we'll see you at GSR and Chesapeake!
www.team1058.com/media/video/Drive_Test_2010.mov
Unread 25-02-2010, 18:04
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
That is very impressive, i can easily see how that software would make for a huge advantage in the 08 game. This year it might cause some problems as you can't climb the bumps while not directed right in front of them, but you must save it for future years, it's amazing.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 25-02-2010, 18:21
Bob Steele's Avatar
AKA: Bob Steele
Our robot uses the same idea this year... I think it will serve us well.
We use a single joystick for that translational motion and a dial to rotate the robot on its center (We are using a mecanum)
I will be interested to see how you do on the field. I bet it will be very useful!!
Great job on both the programming AND the explanation...
I hope we see you in Atlanta!!
Unread 25-02-2010, 18:41
BrendanB BrendanB is offline
AKA: Brendan Browne
Very nice Brendan! I remember you telling me about it at the unveiling, but I didn't think it would work. That is really cool! I want to drive it!
See you at GSR!!
1058 PVC Pirates 2016 - xxxx
Unread 25-02-2010, 18:52
CraigHickman
Posts: n/a
Wow. Your team should be incredibly proud, as that is one of the smartest drive systems I have seen in FIRST. Seriously good work.
Out of curiosity, what sensors did you throw on there? I'm guessing gyro and compass, possibly accelerometer, but I'd be curious to see how they interact, and what controls what.
Unread 25-02-2010, 18:53
AKA: Mike Jr.
Don't worry. We have a solution for that! We get over the bumps just fine!
Unread 25-02-2010, 20:58
familyguyfreak's Avatar
familyguyfreak familyguyfreak is offline
AKA: Xavier Eldridge
FRC #4209 (TigerBytes)
familyguyfreak is an unknown quantity at this point
Send a message via AIM to familyguyfreak
Amazing! I'm speechless! Awesome work guys!
Good luck in all of your regionals!
DiscoBots:
2009: Member
2010-Present: Mentor
TigerBytes:
2012-Present: Mentor
Unread 25-02-2010, 21:09
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Really neat drivetrain control system! Really wish our team used a drivetrain like that so we could program it to act as such.
Very nice job. Bravo.
-Tanner
Unread 28-02-2010, 21:51
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Wow, I just was just informed about this thread...
Thanks guys!!!!!!
I didn't realize people would love our drive system so much...Me and my friend Brian spent about 3 math classes (with somewhat aprooval of our teacher) writing psudo-code for this....because the code that WPI gives us was lables as "experimental" so we decided to write it all custom...plus its more fun that way
paper: Drive Train Field Calculations JesseK Extra Discussion 1 29-10-2009 16:34
Field-Oriented Mecanum Drive ZZII 527 Programming 6 15-01-2008 16:56
Holonomic drive train and field-based control dmlawrence Technical Discussion 20 18-11-2007 22:17
Field oriented holonomic code? chaoticprout Programming 4 24-01-2007 23:09
Science Oriented Book Recommendations Kristina Math and Science 9 19-04-2003 02:22
