Hi
I was wondering if the Match info cluster will be used at competitions I see that it is being used in telop and in auto. Is it possible to link other code to this information? For example with finale to not allow certain things to happen until then. |
Re: match info questions
Yes the Match Info cluster is used at competitions. And yes you can link other code to this information - that's kind of the whole idea of having it.
Yep.
My team is using it in a couple ways ... we use TeleopElapsedTime to lock-out our finale stuff until after 100 seconds ... and we also use the "visited" variables to do different things in the DISABLED.VI because it gets called 4 different times during a match. |
| [TBA]: outdated Team Info in Match Archives | adengler | The Blue Alliance | 5 | 08-03-2008 14:57 |
| Match list info | nuggetsyl | General Forum | 2 | 26-11-2007 22:09 |
| **FIRST** **FVC Team Info** **Important Template Info** | Mark McLeod | FIRST Tech Challenge | 0 | 21-02-2007 12:41 |
| Spring pulling before match or while in match?? | Bomberofdoom | Technical Discussion | 3 | 11-01-2007 08:03 |
| Pre-Match/Post- Match Pit Routine | Mark_lyons | General Forum | 14 | 31-03-2002 15:19 |
